If it only leaks when it is on then it shouldnt be hard to track down. Once the car is on the pump is primed so its just a matter of following the fuel line from pump onwards...My guess is its a clamp thats loose or a splitting fuel hose....Fix it ASAP
https://www.sau.com.au/forums/topic/266560-petrol-leaking/#findComment-4549893
I had the same problem when I fitted my 044. The "out" line hose of the fuel pump had split by the pump. That is why as soon as the pump primes or the car is running, the petrol spills. Open the access panel in the boot, get someone just to turn on the ignition and you should see the leak. Its a bit of a pain to get the new hose through, get someone to help you out when doing the job.
https://www.sau.com.au/forums/topic/266560-petrol-leaking/#findComment-4549934
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
