Terrorism is an ongoing threat in many areas around the world. The threat in some destinations is very high. We continue to receive reports that terrorists are actively planning attacks. Australians could be caught up in attacks targeted at others. Terrorists may attack official or civilian targets depending on their particular objectives at the time.
Travel only if required
https://www.sau.com.au/forums/topic/266652-travel-advice/#findComment-4550544
ohhhh kkkkkkk....
we've stayed at Skene's Creek hotel once, really nice, it's a bunch of cabins nestled up in the hill amongst the tree's, which is exactly what we're after. Amongst the trees but with ocean views.
not sure how central you want to be, but we really liked our stay at Skene's Creek hotel/lodge, something-a-rather
https://www.sau.com.au/forums/topic/266652-travel-advice/#findComment-4550549
ohhhh kkkkkkk....
+1 for Skene's Creek Lodge. went their recently on the last GOR cruise. nice rooms and location. very close to town aswell
https://www.sau.com.au/forums/topic/266652-travel-advice/#findComment-4550567
lol thats a funny post but kinda doesnt answer his question.
so if your after a relaxing holiday go to apollo bay i used to go there evey year and stay in holiday homes there the best. there are lots to choose from i cant remember the one we go to though but its really good. its nice and relaxing there because there isnt heaps of people around plus there are lots of good hiking spots around and fantastic views, one side is the ocean and the other are the hills i love it. its right near skene's creek anyway.
https://www.sau.com.au/forums/topic/266652-travel-advice/#findComment-4550926
In the past when running the GOR Cruises we have stayed at the Skenes Creek Lodge Motel.
Its about 5 min out of Apollo and has great views. And they really look after us..
So give Andrew and Doris a ring on 03 52376918 and tell them Wayne Beaumont from Skylines Australia-Vic
sent you..
Cheers
Wayne..
https://www.sau.com.au/forums/topic/266652-travel-advice/#findComment-4551038
sent you..
Cheers
Wayne..
Thanks for all your glowing recommendations of Skenes Creek Lodge Motel.
Booked and I dropped your name Wayne.
Cheers.
Edited by zero-R33-
https://www.sau.com.au/forums/topic/266652-travel-advice/#findComment-4551151
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
