  • Replies 80
nah i dont have any problem with that
its the damn gay ass telstra tool bar with uptodate usage meter...its not up to date all the time! and doesnt dispense gold out of my computer! what the hell?!?!?!
hehe
when did u go get dyno? (cant reply going bed now)
you loose approx 9 kw from the auto box.
My Dyno result was a 203 rwkw on 13psi.
But i have the following.
Fuel pump
T04e/gts-r exhaust manifold
ARC front mount
3" zorst
and i think a slight possibility of a modded diff/gearbox (but i have no idea on that one)
Looking at your graph that's a very typical shape.
I've seen that shape out of a number of cars with similar mods.
BUT at the end of the day, all you use it for is to compare the next time you do more mods, on compare as a group on a dyno day.
If you do another mod (say a cooler) and get it re-tuned then you compare that with your previous figure/graph and go from there. Just because you made 127rwkw means nothing.
It has nothing to do with 'whos' dyno is more accurate, or reads higher.
As long as you use it for a base of comparison and use that dyno consistently. Chopping and changing dyno's doesnt help as figures and readings will vary
hope that clarifies.
ash
hey guys, i was wondering would this have anything got to do with the AFM? haven't checked if they are clean etc.. oh almost forgot , also have K&N Panel filter.. car just done 86,000km , close to change timing belt and fuel pump. Would this help increase some rwkw?
Thanks for all your feedbacks ppl. Much appreciated... :)
If its auto it explains the 10-20rwkw loss. Depends on the condition of the auto as well, if its slightly shagged it'll slip a little under high revs..
Anyhow, who cares about dyno figures.. as long as the car feels harder and runs a good 1/4 mile time then i wouldn't worry too much.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
