About September last year Cat's race engine suffered a failure after running 3 laps free boosting (35+ psi). Initial thoughts on the day were a damaged valve but (slight miss and knock) a few more starts at the track to try pinpoint the noise the missing stopped and only a slight knocking remained so I dismissed valve train issues.... trying to pinpoint the knock was difficult at a noisy racetrack but it was definitely not the usual bottom end knock it was quieter. Knowing the engine needed a strip down I pushed it aside and left it parked gathering dust. With a new business and all the extra cash all being re-invested on new workshop equipment and setting up the showroom the car sat gathering dust for 6 odd months... very depressing.
After strip down it soon became obvious as to the source of the noise and thankfully it was not the bottom end, my trust pistons and Tomei rods were safe as was the "use what I had" r32 crank (complimentary 3 thou bend :D ) with a pro-engines collar. The crank will be retired (new cranks from NISSAN are ridiculously cheap now) and replaced with a new R34 GTR item.
The cause of the noise was a broken intake guide, the guide had broken and attached itself to the top of one of the pistons and was digging a nice hole in the quench area (hence the light knock). The head was recoed 12months back but due to the rushed build of this engine (3days from machining to competing) the inlet side was left alone. The exhaust was treated to new guides and valves but the inlet side all measured up ok. Usually finding the cause of guide failure is easy but in this case there were no tell tale signs. Common causes are impact, poor lubrication, incorrect valve stem height etc. In this case only a very small portion of guide was missing, usually the whole tip comes off during failure not just a small fragment... even the valve stems were clean and undamaged, the remaining guides were all perfectley serviceable..... There is a first for everything.
The old build recipe;
R33 block
Trust pistons
Tomei H-beam rods
King bearings
Trust oil pump
Trust head gasket
Status Oil restrictor kit
Tomei sump baffle
R32 crank with Pro-engines collar (3 thou bend :) )
Std R33 head with new ex valves and guides
Relieved cam valley for big lift cams
Trust 264 9.7mm lift cams (babies for now)
Std Plenum
The new recipe is basically the same but with a big $$$ head setup;
R34 crank
MLS head gasket
King bearings
Ferrea 1.5mm oversize valves in and ex.
Ferrea Titanium retainers and collets
Ferrea Double valve springs
Ferrea Spring locators
New Genuine buckets and shims
New guides
Larger rear housing for the K5-660R, after we get a baseline comparison with the old engine.
Nismo intake plenum as we found the STD one was compromised for flow distribution.
Link G4 (Vipec) ecu but only after car is fully sorted on the PFC D-Jetro as there is no real reason to swap other than using it to demo features to customers, I feel the Link fills or offers an alternative for those who can’t source the now more expensive PFC as easy. The PFC will retire to my C34 RB26 Laurel.
With the fresh build we will to try out a few new things which will end up in customer engines provided they prove reliable.
Pics up soon as I will do all the assy 2moro as I won’t get hassled or interrupted.
The new store project car is a C34 laurel which started out with a T78 equipped rb26 but currently is engine less and awaiting its new power plant.
Engine recipe is more budget based and will be used to develop a budget setup, many of our SR20, RB25 and 26's seem to be for pretty serious customers and have all been up there for $$$ build wise due to the components used and the proven nature of the builds (zero failures to date). So i decided to put together something fairly simple.
This budget engine will be abused to within an inch of its life, yet cheap to build including the supporting turbo etc....
R32 block
Status oil restrictor kit
Resized STD rods
Pistons (under testing atm)
R32 crank pro engines collar
N1 oil pump
King bearings
STD rb26 head
Kelford springs
T4 external gate manifold
Tial gate
HX-35 turbo
Again pics up soon of engine and car.
https://www.sau.com.au/forums/topic/267069-new-rb26-race-motor-build-thread/
How did you measure this? I agree but would like to know if the nismo item makes any difference.
edit to ask, will the vipec/link allow individual cylinder corrections based on load?
Edited by DCIEVE
Sure can mate. You can trim each cylinder individually using either a single amount OR using a full 3d map, and you can set the X & Y axis to be whatever you want it to be.....Go LINK ! :/
Gary
is cat still going to use the good engine?
yeah she will get the good one, we will probably start to do alot more grip setup as we are planning to hold our own track days (grip/drift) for our customers next few months. With the folding of DA we are finding more and more people wanting mixed days.
EGT's and good old plug reading.
I've taken bit of a plunge here with the nismo item based on some conversations with some of my jap contacts, i would love to do some back to back tests with the hypertune item and the greddy version against the Nismo.....
Edited by URAS
What cams with the big $$$ head, or is that a secret?
Also, sticking with the Blitz K5-660R, staying with a good thing. Do Blitz have a split pulse option on their housings?
Sounds exciting, 1.5mm oversize valves!!!
mis-type on my behalf, 1mm overs only..... i was thinking .5mm over on the pistons but typing in the valve specs.... by the time i went bak in i could not edit it.
the Blitz stuff is not available in split pulse.
Cams are only babies atm 264 with 9.7mm lift, gonna do some testing on the camtech stuff.
few pics:
I was very impressed with ATI's 7" balancer, cant wait to get it all fitted up.
rest of the pics are pretty general, pic of the crank and its grub screws (NEVER leave the factory alloy plugs in), Arp main and head bolts, H-beam rods etc
CBF'd assy it yesterday as ive got so many motors on the go in the shop....i went to the melbourne comedy festival and saw Arj Barker and Tim Minchin instead ;)
Edited by URAS
Decided to run the TRUST plenum as i can have it here 2moro, so if anyone wants a cheap (brand new) HKS 11mm fuel rail let me know as the TRUST plenum i bought comes with a rail kit.
Edited by URAS
Who sells the ATI's in OZ Trent ? They do a rb25 one too ? What price ?
Gary
i needed mine asap so i ordered it via may machinist, I reckon mine came from precision parts here in vic i paid about $906
CJ have them a bit cheaper here http://stores.shop.ebay.com.au/cj-motor__W...Q_fsubZ20921914
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
