About September last year Cat's race engine suffered a failure after running 3 laps free boosting (35+ psi). Initial thoughts on the day were a damaged valve but (slight miss and knock) a few more starts at the track to try pinpoint the noise the missing stopped and only a slight knocking remained so I dismissed valve train issues.... trying to pinpoint the knock was difficult at a noisy racetrack but it was definitely not the usual bottom end knock it was quieter. Knowing the engine needed a strip down I pushed it aside and left it parked gathering dust. With a new business and all the extra cash all being re-invested on new workshop equipment and setting up the showroom the car sat gathering dust for 6 odd months... very depressing.
After strip down it soon became obvious as to the source of the noise and thankfully it was not the bottom end, my trust pistons and Tomei rods were safe as was the "use what I had" r32 crank (complimentary 3 thou bend :D ) with a pro-engines collar. The crank will be retired (new cranks from NISSAN are ridiculously cheap now) and replaced with a new R34 GTR item.
The cause of the noise was a broken intake guide, the guide had broken and attached itself to the top of one of the pistons and was digging a nice hole in the quench area (hence the light knock). The head was recoed 12months back but due to the rushed build of this engine (3days from machining to competing) the inlet side was left alone. The exhaust was treated to new guides and valves but the inlet side all measured up ok. Usually finding the cause of guide failure is easy but in this case there were no tell tale signs. Common causes are impact, poor lubrication, incorrect valve stem height etc. In this case only a very small portion of guide was missing, usually the whole tip comes off during failure not just a small fragment... even the valve stems were clean and undamaged, the remaining guides were all perfectley serviceable..... There is a first for everything.
The old build recipe;
R33 block
Trust pistons
Tomei H-beam rods
King bearings
Trust oil pump
Trust head gasket
Status Oil restrictor kit
Tomei sump baffle
R32 crank with Pro-engines collar (3 thou bend :) )
Std R33 head with new ex valves and guides
Relieved cam valley for big lift cams
Trust 264 9.7mm lift cams (babies for now)
Std Plenum
The new recipe is basically the same but with a big $$$ head setup;
R34 crank
MLS head gasket
King bearings
Ferrea 1.5mm oversize valves in and ex.
Ferrea Titanium retainers and collets
Ferrea Double valve springs
Ferrea Spring locators
New Genuine buckets and shims
New guides
Larger rear housing for the K5-660R, after we get a baseline comparison with the old engine.
Nismo intake plenum as we found the STD one was compromised for flow distribution.
Link G4 (Vipec) ecu but only after car is fully sorted on the PFC D-Jetro as there is no real reason to swap other than using it to demo features to customers, I feel the Link fills or offers an alternative for those who can’t source the now more expensive PFC as easy. The PFC will retire to my C34 RB26 Laurel.
With the fresh build we will to try out a few new things which will end up in customer engines provided they prove reliable.
Pics up soon as I will do all the assy 2moro as I won’t get hassled or interrupted.
The new store project car is a C34 laurel which started out with a T78 equipped rb26 but currently is engine less and awaiting its new power plant.
Engine recipe is more budget based and will be used to develop a budget setup, many of our SR20, RB25 and 26's seem to be for pretty serious customers and have all been up there for $$$ build wise due to the components used and the proven nature of the builds (zero failures to date). So i decided to put together something fairly simple.
This budget engine will be abused to within an inch of its life, yet cheap to build including the supporting turbo etc....
R32 block
Status oil restrictor kit
Resized STD rods
Pistons (under testing atm)
R32 crank pro engines collar
N1 oil pump
King bearings
STD rb26 head
Kelford springs
T4 external gate manifold
Tial gate
HX-35 turbo
Again pics up soon of engine and car.
https://www.sau.com.au/forums/topic/267069-new-rb26-race-motor-build-thread/
How did you measure this? I agree but would like to know if the nismo item makes any difference.
edit to ask, will the vipec/link allow individual cylinder corrections based on load?
Edited by DCIEVE
Sure can mate. You can trim each cylinder individually using either a single amount OR using a full 3d map, and you can set the X & Y axis to be whatever you want it to be.....Go LINK ! :/
Gary
is cat still going to use the good engine?
yeah she will get the good one, we will probably start to do alot more grip setup as we are planning to hold our own track days (grip/drift) for our customers next few months. With the folding of DA we are finding more and more people wanting mixed days.
EGT's and good old plug reading.
I've taken bit of a plunge here with the nismo item based on some conversations with some of my jap contacts, i would love to do some back to back tests with the hypertune item and the greddy version against the Nismo.....
Edited by URAS
What cams with the big $$$ head, or is that a secret?
Also, sticking with the Blitz K5-660R, staying with a good thing. Do Blitz have a split pulse option on their housings?
Sounds exciting, 1.5mm oversize valves!!!
mis-type on my behalf, 1mm overs only..... i was thinking .5mm over on the pistons but typing in the valve specs.... by the time i went bak in i could not edit it.
the Blitz stuff is not available in split pulse.
Cams are only babies atm 264 with 9.7mm lift, gonna do some testing on the camtech stuff.
few pics:
I was very impressed with ATI's 7" balancer, cant wait to get it all fitted up.
rest of the pics are pretty general, pic of the crank and its grub screws (NEVER leave the factory alloy plugs in), Arp main and head bolts, H-beam rods etc
CBF'd assy it yesterday as ive got so many motors on the go in the shop....i went to the melbourne comedy festival and saw Arj Barker and Tim Minchin instead ;)
Edited by URAS
Decided to run the TRUST plenum as i can have it here 2moro, so if anyone wants a cheap (brand new) HKS 11mm fuel rail let me know as the TRUST plenum i bought comes with a rail kit.
Edited by URAS
Who sells the ATI's in OZ Trent ? They do a rb25 one too ? What price ?
Gary
i needed mine asap so i ordered it via may machinist, I reckon mine came from precision parts here in vic i paid about $906
CJ have them a bit cheaper here http://stores.shop.ebay.com.au/cj-motor__W...Q_fsubZ20921914
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
