on my r33 gtr.
since buying it couple months ago.the pedal has always been stiff.
i dont think the brakes have ever been changed. niether have the disc's or fluid
do u reckon it could just need to be bled ? or im up for some disc's and pads
if so what do u reconmend?
thank you Chris.
https://www.sau.com.au/forums/topic/267353-hard-brakes/
Wow.. now thats new, a complaint about a stiff brake pedal in the sea of complaints about soft brake pedals... feel like swapping brakes? lol
Does it slow down fast or not as good as it should do?
hahaha.. nah it stops like shit. i have to push really hard for it to pull up.. iv just bought some dba4000 drilled/slotted and some endless pads .. and gonna flush the system. i think thats the problem.
i think thats the problem so ill let yous know how i go
https://www.sau.com.au/forums/topic/267353-hard-brakes/#findComment-4561072
Make sure that all your pistons are moving freely when u have the pads out, they may be siezed a bit... If they are all moving freely then what ure doing should solve your problem
https://www.sau.com.au/forums/topic/267353-hard-brakes/#findComment-4561266
sweettaa... thanks alot for your help.. ill let you know how i go on thursday :)
https://www.sau.com.au/forums/topic/267353-hard-brakes/#findComment-4561289
also could be the brake booster is not working if the pedal feels like stepping on a lump of wood. put your foot on the brake with the car off and start it - does the pedal sink a bit?
yeh it does.. its not the booster iv already tried lol
but thank you anyway
https://www.sau.com.au/forums/topic/267353-hard-brakes/#findComment-4561675
Look the chances of it there being something fundamentally wrong with the system are remote. If it was a seized caliper the car would pull hard to the left or the right.
A seized master cylinder would not allow the pistons to return from the depressed position - hence the brakes would be on more often than not.
It won't be fluid.
The chances are some nugget has fitted a well hard set of brake pads. My first R had something similar. It would take what seemed like month of Sundays to stop. This fix was as difficult as getting some new pads & replacing the (wornout) rotors. Obviously new fluid would be done at the same time.
https://www.sau.com.au/forums/topic/267353-hard-brakes/#findComment-4562335
My brothers 32R has the exact same problem, really hard pedal. But if you push it hard it pulls up evenly, so i dont think its calipers. And you can get the brakes smoking after a decent workout so i doubt its "racing" pads.
Is it common for the master cylinder to clap out on these? His car is 15yrs old now so it wouldnt overly surprise me, but i just havent heard too much about failing master cylinders in the skylines.
Its quite funny because my stock na brakes shit all over his atm haha
https://www.sau.com.au/forums/topic/267353-hard-brakes/#findComment-4571089
lmfao.. iv changed my discs to dba4000 cross drilled rotors with new pads and flushed the brake system
it fixed the problem. my braking has almost doubled and the pedal feel is awesome now
if anyone is after some dba4000 cross drilled rotors. let me know i have for sale
https://www.sau.com.au/forums/topic/267353-hard-brakes/#findComment-4573673
really? so you didnt change anything to do with the calipers or master cylinder?
Do your old setup ever get "better" after you got the brakes hot? Did you take note what pads came out (brand etc)?
I would of thought shitty fluid would of given a spongy feeling (since its not compressing properly), the rotors shouldnt really have much effect unless they are cracked so that just leaves the pads as the culprit.
how much did you want for the rotors haha? did you have front and rear or just the fronts?
https://www.sau.com.au/forums/topic/267353-hard-brakes/#findComment-4574087
  • 11 months later...
I've got the same problem- really hard pedal, little feel.
I thought, shitty pads and old crap fluid. So i bought and fitted new pads all round and completely flushed the fluild and bled the ABS master.
Absolutely no effect. ABS works, i've got to push like an elephant though. SO, that leaves the booster i guess. Is there anyway to test it, or do just have to replace it?
Or what about the master cylinder- i guess the piston could be semi-seized?
Thanks for any suggestions
Edited by Simonster
https://www.sau.com.au/forums/topic/267353-hard-brakes/#findComment-5175282
yeah easy to test....block off the vacuum from the motor to the booster and see if the feel changes. I ran the race car with a busted booster years ago it was terrible (pedals designed for no booster have a different leverage).
BTW I owe you an overheating pm....one day that motor will be stripped, next few weeks I hope to have info
https://www.sau.com.au/forums/topic/267353-hard-brakes/#findComment-5175298
One of my brake cylinders in side on of my drums was seized and gave me a hard brake pedal, i thought it was normal until i replaced them and it got much softer.
So yeah, check that your callipers are working good
https://www.sau.com.au/forums/topic/267353-hard-brakes/#findComment-5175513
+1 on that
Could be a slight vacum leak in the brake booster, causing it to initially feel fine - then as the brakes are applied harder more vacum will leak - therefore stiff brakes and brakes that do not pull up as good.
I had a similar issue on my bluebird. Changed brake boostrer and no issues since.
https://www.sau.com.au/forums/topic/267353-hard-brakes/#findComment-5176113
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
