I think this guy is after the ol 'shed' burnouts, reminds me of wankers who pour oil down over speed humps at the local cruising spot here so their minitruck can rip it up yeaaaah. Brakes should not be needed for a burnout in a manual at all.
doing a 1 minute + burnout in an rb will have most of the oil left sitting in the top of the head as the stock returns are not adequate, you will then starve the bottom end of oil and as you say... f**k your engine... get the reply yet?
would love to see u guys rip a straight 1 minute burnout without using the brakes.. without f**king ur engine.. get the question yet?
Noobcake. You have one too many o's, and are missing a K.
No more serious, or even semi-serious replies to this thread - PLEASE
Can moderators close this thread on the fact that it lowers the respect for the entire forum?
This is a car enthusiast website, not about pulling a fully sick 1 minute burnout inside your garage...
P.S. buy cheaper tyres :cool:
P.S. buy cheaper tyres :P
Now that is a serious post.
Funny interesting fact. If you google "ABS burnout" on the aussie google, this is the first link that comes up :)
Reason i found that, is i was wondering if locking the front brakes up while doing a skid on a ABS car puts stress on the ABS unit.
Edited by PM-R33
so what makes doing a line lock in your friends cardboard mansion cool i have to ask? if u wanna smoke em up go out to a burnout comp or better yet learn to drift. stop being a tool line locks cause so much damaging stress on your ride why would you want to.
now turn around so i can slap you in the back of the head
Cawk, cawk...Squawk squawk squawk
just wondering if u can, ma mate owns an r34 wit ab's and when he tries to rip it off the abs will jus kik in.. its manual btw
Squawk squawk squawk......Squawk squawk squawk
you guys aint very helpful.. my brakes stil lock up /shake while tryin to do a 30 second burnout
Cawk, cawk, cawk cawk cawk
Wanna apple?
Edited by madbung
I really hate helping people destroy their cars, but for the sake of this twit going away and in the absence of moderators locking the thread:
A. Disconnect or short your rear ABS sensors
OR
B. Disconnect your rear brake lines and block them off
OR
C. Buy a couple of brake bias valves
I too am waiting for the "how do I rebuild my engine/diff/gearbox/car" thread.
My god you really are a noobcake! as if you come on a forum that is serious about the car scene and within your first hanfull of posts you put up this rubbish..
if you really want to bag it up...put your bumper up to your garage wall of your mates mansion and then floor it...
Edited by Slow S13
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
