hi all i have a full bolt in 6point roll cage for an r33 black in colour - SAFETY 21 - KTS technical pro shop real sport & competition advantage/parts & equipment.
Has full bright canary yellow foam padding to go with it, All up its worth $1200 but willing to streight swap for a power fc with hand controller to suit an r33 gtst in "near new condition" if no1 is willing to swap?
I bought the cage with the intension of puttin it in an going to QR but never got round to it.
I'm located near QLD border for those who might want to view the cage
My R33 is practically stock atm an i'm lookin to make some hp any tips for good "cheap" hp while i'm searching?
will post pics over the wknd if i get the chance
this cage was not on ebay, i bought this off a good friend that had it in his r33, its for a non sunroof skyline, would prefer to swap for a power fc but any realistik offers are welcome
Is the cage CAMS approved? I'm assuming it'll fit a R33 series 2 '96
I'm very interested. I will buy you a brand new l-jetro (ecr33 rb25det) power fc lol.
Please PM me
cage will fit s1 and s2 R33's 93 to 97.
pm sent
Edited by MAFIA R33
Please PM me
Good Luck getting a brand new one lol
but yeah.....+1 on pics
sry guys been flat out lately but i promise i'll get ya's some pics through the week!
Realy keen on ecr33 rb25det apexi power fc tho so if any1 wants a lagit r33 cage for 1 i'm open for swaps!
looks sik as cruisin down the road when bolted in!
You got P.M
ur inbox must be full mate cant pm u back
yes will fit R33-GTR/GTST series 1 & 2
all other pm's replied, keep the interest comin ppl
Edited by MAFIA R33
have you seen how much a power fc is? i dont you will find anyone that will swap a near new power fc for a $1200 roll cage.
but anyway good luck with it.
yeh i know i wont get a new 1, found an apexi site with 8 new power fc's left for R33 GTST from U.S for $1,121-AU, if no1 will swap i'll just buy 1 new from the states :)
I can give you an idea why your having problems selling/swapping this cage. The "KTS" safety 21 cages can be bought from http://www.tokage-racingimports.com for $800. The genuine Cusco Safety 21 cages are about $1200. Hope this information helps you get you PFC.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
