Hi Fellas,
A simple question, yesterday I was cleaning out my ACC, and when I was putting it back on, I kept tightening the bolts it but it never seemed to end.
I could feel it was on tight, but as a kept screwing it didn't feel as though it was getting progressively harder to screw, but it was still fairly hard, do you get what I mean?
In any case, have I F$%ked something up?
Could there be a leak between the plennum and the ACC valve now that this has happened, and if so, how can I tell if there is a leak?
I am one paranoid mofo!!!! WOOWOWOWOWOOWOWOWO
Any help would be great
https://www.sau.com.au/forums/topic/267760-how-tight-to-do-up-bolts/
It states in the manuals the torque settings, for the AAC Valve it is 6.3 - 8.3Nm which is fairly tight, best thing is to get yourself a torque wrench so you can be sure its to manufacturing standards :O
mm, but I got a plazma man plennum, maybe because it's aluminium it's different feeling now?
you need to be careful screwing into aluminium, the chances of stripping the thread is increased, you dont want to do this!
yes it will feel different, more "spongy" if you like
personally i would do it up until you can see the aac valve pull all the way up onto the gasket then maybe another full turn or two, depending on thread pitch
plumbers tape is a thin white elastic tape also known as teflon tape. you just stretch it over the bolt that u tightening and then screw it back in. most times, a couple of times round is heaps.
can buy it from bunnings, super cheap and even auto bahn.
Edited by cheez
ahhhh shit, I turned it like 5 turns after it hit the gasket........
Does this mean it's gonna leak now?
if its still tight...possibly not, but always check the pitch on the bolt first, say the pitch is 1.25mm, (assuming im correct) one complete revolution equals a movement of 1.25mm, so 5 turns would work out to be 6.25mm of movement!
Edited by Zurlox
Ahhh bugga, not to worry......
How will I know if it's leaking pressure?
You will probly hear it hissing...
Why dont you wind the bolt out and put a new one in?
You could have also stretched the thread, and when they stretch too fat they go bang, and you have half the bolt in your hand :O
have u go the correct bolt in there?
a 5mm will turn forever in a 6mm hole
Yeah it's definately the right one, it just feels different mounting it to the alloy plennum.
As that other fella said, feels spongy instead of getting progressively tighter.... I think it should hold up. I'll test it tonight see if I get any boost dropping off.....
zurlox, 6.3 - 8.3nm isnt tight at all... probably only a little bit tighter than u can do with a screw driver.
if its turned more than twice in aluminium then its nearly deffinatly stripped the thread.
should spray water around it when its running and see if it leaks. if its turbo then the boost could force it open then there will be a leak
i think best bet would b to find sum1 with a thread tapping set and re tap it and fit a new bolt..... but if the threads totally gone then u might have to get it inlarged to the next size up as there will be nothing to tap.
or mayb get a helicoil put in????
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
