  • Replies 492
Posted Images
i cant be fecked finding my posts again. but yeah, im enjoying a maynard james keenan themed week.
belting out some old school tool, a perfect circle, and puscifer.
dont often have a chance to head to gigs (works a bitch like that), can count the number of gigs ive been to in the last year or so on one hand.
pennywise, strung out, rise against, slipknot and the 'oars.
slipknot was a good gig... would love to see them again
cog, butterfly effect and karnivool playin in the next 4-6 weeks. should be fun
-D
Edited by Dohmar
oooher, butterfly effect? for srs bro? when/where?
slipknot was an awesome show. was funny seeing so many people go 'oh, is that it?' and walk out after they finished their first set and reset the stage.
Friday 17th July, Thebarton Theatre $33 presale tickets $38 at the door
Butterfly Effect with Dead Letter Circus, & Calling All Cars (dont know either but for $33 I'll be there)
-D
kinda like dubstep, its like drum n bass, but better
Yeah Im addicted. Prolly not hard to tell.
Still like d&b tho. heading to a good show on sat actually. Melbs best DJ that hosts Kiss fm over there.
Crown n scepture.
http://www.youtube.com/watch?v=a7MjLSzD0nw...feature=related that's some quality d&b. Spor.
Joined his forum and had a chat. cant believe he uses Fruityloops and soundforge to get sounds like this. amazing.
