  • Replies 492
Posted Images
gotta love a bit of tech house
did you get some turntables as well as the mixer Craig?
I'm going to do a digital haul on Stompy.com this week. Gonna buy some of the latest deep house that hasn't been mass produced and is a little hard to find on vinyl
yeah mate. Got some stanton tt's coming this thursday.
CDjs coming this week depending on the cash flow.
This dude on ITM is selling a huge collection of vinyl. Hes got it all on excel . most for $6. Im getting a bunch of him. Nice guy too. have a look.
Got plenty of dubstep coming from the UK also.
Mainly gonna concentrate on tech house, prog. plus dubstep.
whats a good program to make your own mixtape? nothing fancy, just to mix songs into eachother as they finish/start.
burning via Nero will allow you to have no time gaps between tracks.....also another good thing is a middy mixer they pretty much give you a lot of control...mix and mash your own way....or you can just get some DJ's mixes like i do :)
If you just want to make a basic mix with some house tracks or something Damo, you can try NI Traktor DJ studio, basically two virtual decks with pitch, a cross fader, EQs, and some basic effects. You can record a whole mix set and it will write it for you as a wav file. Pretty cool to stuff around with.
Once you have the written wav file from Traktor, use Nero to burn it to CD - use the Nero Wav editor (like the guys have said above) to cut it up in desired spots, tick 'no pause between tracks' when you go to burn to CD. Ive been using Nero wav editor like this for ages when cutting up DJ sets and burning em to CD
Here is something from a very good mate of mine DJ - 2J
http://www.trancesa.com/mixes/Trancfixtion...(19-8-2009).mp3
right click save as :)
-Tracklist-
Skytech - Cardboard Box (Original Mix)
Smashing Pumpkins - Disarm (Randy Boyer Mix)
Sander Van Doorn Pres. Purple Haze - Bliksem (Original Mix)
Smart Apes Featuring Kate Miles - Smile (Michael Angelo Vs Silver J Catania Remix)
Bakke & Joni - Envision (Kris O'Neil & Simon Gain Remix)
Andy Moor & Ashley Wallbridge feat. Meighan Nealon - Faces (Original Mix)
Mark Norman - Coffee Break (Gustav remix)
Sean Tyas and Simon Patterson - For The Most Part (Marcus Schossow Remix)
Rank 1 - Symfo (Marcus Schossow & Robert Burian Remix)
First State feat. Anita Kelsey - Falling (Richard Durand Re-Work)
Sean Tyas - Seven Weeks (Original Mix)
Ronald Van Gelderen - Backstabberzz (Ummet Ozcan Mix)
Art Of Trance - Madagascar (Richard Durand Remix)
Rex Mundi feat. Susana - Nothing At All (Elevation Remix)
Ummet Ozcan Vs. W & W - Synergy (Original Mix)
Saints And Sinners - Peace (Breakfast Remix)
Woody Van Eyden - B.O.B (Ummet Ozcan Remix)
BeGold - Starstruck (Jochen Miller Remix)
Craig Gallon - 1186 (Ben Gold Remix)
Yeah i have dabbled with Traktor before, pretty easy to use, but i think it didnt let me record unless i purchased the full version? Nothing a torrent search cant fix :)
have a 'full' version of Pro DJ. Its pretty good. You can mix. add samples. basically like a real mixer. Minus the great effects etc.
You can also record direct to your harddrive in mp3 format or whatever your after.
Can send it to you. Might be on demonoid too
virtual dj mate.
there are a couple diff versions, but I guess they all do the same.
Remember Its a live mixing console tho. So youll have to sit there and actually mix the songs live and record.
Did you find it ? or you want me to dig it up for ya ?
there prolly is. Not too sure mate. Havent played with many comp DJ progs.
you should grab virtual tho. Youll prolly have some fun
Plus you can cut songs short if they get boring and blend in your next track. Live decks on the screen so you know what your doing. And a sorta simple beats per minute display.
what style of music you gonna record ? If its a dance beat. doof beat youll find it easy to blend.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
