I want to change my gearbox oil and diff oil. I know that Redline is one of the best oils for a car's gearbox. Helps synchro's work better.
BUT. I remember hearing/reading that the lightwieght shockproof gear oil is corrosive for the gearbox.
On the website it says:
A unique gear oil designed to lubricate racing transmissions and transaxles which see serious loads (not recommended for most syncro-type transmissions).
Does that mean it will corrode your gearbox. I also hear it only lasts for 10,000kms. Not 80,000 like normal gear oils.
And will that corrode the LSD of my R32, with a RB25DET engine and box.
So I was wondering if I shoudl just get Redline superlight shock proof oil. Or Royal purple maxgear.
  • Like 1
https://www.sau.com.au/forums/topic/267969-gearbox-redline-oil-vs-royal-purple/
I have only had good experiences with Redline Shockproof oils in my R33 GTS-T.
I run Shockproof Heavy in the diff and it has tightened up the diff quite nicely. I also tried it in the diff of my R33 GTR but it tightened the diff up too much to the point where it was becoming more of a locker so I swapped it over the Motul instead.
I have used Shockpreef light in my GTS-T gearbox with no problems. It seemed to smooth out the synchros and improves gear changes. I change my drive train lubricants every 20k and they come out nice and clean. My son then reuses the shockproof light in the gesrbox of his Mazda 626 with no problems.
Redline oils are expensive and these are my experiences.
shock proof is recommended for gearboxes that are in good condition it is able to be used in syncro gearboxes but only if they are in good nick no syncs crunching and all that otherwise your box will have a much shorter life i run heavey weight shock in my rb25 box and its great smooth shifts and engages great recommended it but be prepared to choke at the price
My memory is opposite: MT90 for good condition transmissions, light shockproof to help worn synchros work better (so postpones the inevitable gearbox rebuild). Ring Redline for confirmation.
I emailed them. I hear the distributor is in Ozy Park, So I will call them.
Yeh, pretty sure shockproof is only for race use and worn box's. Not good condition ones. Its either too slippery or just corrosive
^^^i was also under the impression to use it on race cars or worn boxes.
was thinking about putting it into my rb25 box but am a bit undecided if i should use this or use castrol vmx80 with nulon additive.
my gearbox crunches 2nd unless i shift at quite low revs :)
Redline is a real good brand. The normal MT-90 oil they do for good condition gearbox'. Thats what I recomend
MT-90
Popular in Nissan, Toyota and Mazda manual transmissions and transaxles as well as other selected applications, this is a 75W90 GL-4 Gear Oil that’s slightly heavier than MTL. Provides excellent protection of gears and synchronizers and its balanced slipperiness provides a perfect coefficient of friction, allowing easier shifting.
Car - Nissan - Skyline
All-2001 GTS & GTS-T (single turbo) (R32,R33,R34) RB25 & RB25T Eng, 2500cc, 2WD
Component Recommended Oil / Fluid
Motor:
Select your closest climate range. For -10°to25°C use '5W40' or 5°to35°C use '10W40' or 15°to50°C use '15W50'. (* Racing Only - use Race Oils) @ see handbook for Litres
Manual Gearbox:
Select your closest climate range. For -10°to25°C use 'MTL' or 5°to35°C use 'MTL' or 15°to50°C use 'Superlight Shock'. (* Advantage option for Performance / Racing use 'Lightweight Shockproof'.) @ see handbook for Litres
Rear Diff:
Red Line '75W90' Gear Oil (* Advantage Option for Racing use Red Line 75W90) @ see handbook for Litres
Power Steering:
Red Line Synthetic Power Steering Fluid (Bar Code Nos 30404 or RL182-1) @ 0.9 Litres = 1 US Quarts
Cooling System:
Use WaterWetter (Pink) to improve temperature control and reduce corrosion. 1x355ml bottle with distilled water. @ 1 Bottles
Fuel System:
Red Line 'SI-1' Fuel System Cleaner. 1 bottle in petrol tank every 10,000 kms. @ 1 Bottles
Edited by reNEGaDe88
what i have been told is that although the shockproof oil makes your old gearbox good again it is not designed to make it last in other words it will fix all that crappy things happening but it WILL wear quicker and give up quicker than if you were not running it . so if efficiency is your aim then yes use it if durability is your aim then it is not recommended take notice or not i dont care i run heavy weight in my box i would not run light or super light personally and i dont care how long my box lasts as long as it is working at 110 %
Yeh, I want new oil for my gearbox to feel a lil bit better and last long. So I would need something like Redline MT-90 which lasts for 80,000km, unlike lightweightshock proof which lasts 10,000km, and box wears faster.
Cheers
Where did you get that info?
FWIW the standard interval is 100,000 and that's for mineral oil. Synthetics should be more like 300,000.
What a load of crap. I put redline shockproof in about 3 years ago. About 1.5 years ago we changed my clutch and took the fluid out, it looked brand new so we decided to reuse it. I've had the same lightweight shockproof in there for about 30,000km and it still feals like a new tight box.
Nissan recomend you change your gearbox oil every 80,000km. I read that the Redline Lightweight shockproof oil is for race cars with dog box's etc. So it made to give max performance not necessarily max duration. So it only last 20,000km before the compounds of oil break down...
Hate to disagree with again on a different thread but thats incorrect
I have a bottle of redline oil (light shockproof) which i used on my gear box. It says on the bottle that the oil is good for up to 400 000kms.
Ill upload a pic when i find one on my pc.
EDIT:
Found the pic... You will probably need to zoom in on the sticker that has been circled in blue (Save picture as then use windows picture view to zoom in). The bottle is at my workshop. Next time im there ill snap a better pic. But this will have to do for now.
Or alternatively, go to this link.. is a bit easier to see
http://i292.photobucket.com/albums/mm33/br...n79/redline.jpg
Edited by br3ndan
I used redline lightweight in an RB20 box that ran no oil in it for a month.. i bought the car, it whined like a bitch, thought it was almost dead, thought id have a look in their and not a drop of oil came out. so i filled it up with the lightweight and it's good as, been good for 6months now and i thrash it hard.
Cheers
I'd recommend something other than Redline MT-90, when discussing with someone else who regularly uses Redline he recommended Redline MTL, MT-90 is quite thin.
Note: I'm talking about R32/R33 boxes, not R34....
It doesn't work well for my series 3 R33 GTR box (its 10 years old so maybe its worn synchros), so I'm trying Castrol Syntrans 75w85 next
sorry for double post. But I found this on redline tech sheet
CORROSION PROTECTION
The extreme pressure chemistry used in many gear oils
can be corrosive to brass and bronze used in synchronizers
and bushings. Most gear oils are corrosive at
temperatures of 200°F. Red Line Gear Oils are non-corrosive
up to 300°F and the MTL® in excess of 375°F. A
corrosive gear oil can shorten synchronizer life by half
and can also contribute to rust problems.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
