  • Replies 59
looks in the way up there, i did look at them but in my opinion the whole mount looks cheap, think i may go pillar mount or like QWK32 done. just need to find a good looking mount, and a good looking gauge 2moz. ill post pics up of mine when its done!!!
Nope, it's not in the way at all. And the housing is pretty decent quality, it almost exactly matches the colour of the dashboard, so it doesn't stand out from outside the car.
if i could post the pic of what i wanna do but cant cause its a bitmap.
where the ash tray and lighter is, put a 3din in there and have oil temp+press and boost. but need five gauges all so it might change.
was thinking 2 in each corner of the cluster. plenty of room in there to fit them.
(thread steal) post up all your gauge setups people. be nice to get some pictures to some of our ideas :banana:
Don't mount your gauges too low if you're going to want to keep an eye on them.
There's already a thread with heaps of people's set-ups posted (it might be the stereo install thread, I can't remember), and I'll try and find it and link to it here. Regardless, here's what my set-up looks like - you've already seen where my boost gauge is mounted, these three are (L-R) Exhaust Temp, Oil Temp and Oil Pressure...
This is probably the best 3-Defi DIN package EVER IMO. 2x temps and one press. http://www.rhdjapan.com/jdm-low/DEFI-DIN-G...ure-Meter-52178
My current set-up:
The EBC is temporarily there until i finnish the install and hide it, the turbo timer shows boost.
My current set-up:
That Defi unit looks impressive - would slot right into my car but for the $900 I don't have!
i've got that massive Xanvi screen thing, so only choice is down low. and its only for transmission pressure and temp. once i find out where the needle is sitting,. could maybe angle them counter clock wise or somthing.
see iv'e got my Xanvi unit taking up double din. then i have my fold out dvd player and then cup holders. then ashtray and lighter, which dont get used. i'll keep looking
my blitz gauge is in the spare din pocket under the cd player,easy to run the hoses and power lines behind the centre consol.and i took the driver side wheel arch cover out and popped a small hole thro the grommet where the loom runs thro the firewall
My current set-up:
The problem with those gauges is that you can't choose what they monitor, Ryan. I would really have loved to have that as an option, but it didn't suit my needs.
What would you rather they were? i would be doing Water tempp/Oil temp/Oil press.
thrided, definatly the gauges you need, as most people already have a separate boost gauge anyway. but at a price of $700-$800 you could just as easily get yourself three separate 52mm gauges and a din mount gauge holder for atleast half the cost. but the quality of the defi unit would be far superior.
Edited by QWK32
three defi gauges and senders is more i think, and the press gauge does boost too
i was thinking more along the lines of autometer or drift brand or similar. you get everything with the gauge when you buy defi, no need to buy senders and sensors seperatly. but yeah, i think if you were to buy 3 seperate defi gauges they would be around the same cost as the all-in-one unit.
  • 1 month later...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
