thought i'd chuck up some info on my car...
its a 1989 Passage GT
Forged RB25DET
Polished and ported head
RB25 gearbox with short shift
Tomei technical trax 2way diff
600x300x76 FMIC and piping
KKR480 Turbo
Koni adjustable sports suspension
R33 4 pot front calipers with slotted rotors
R33 2 pot rear calipers with slotted rotors
Power FC + hand controller
PWR 42mm alloy radiator
bucket seats
Sparco hyper fang II 17x9 +15 all round
3" turbo back exhaust
Z32 AFM
750cc powerflow injectors
RB26 coil packs
700hp fuel pump
Gates timing belt
clear indicators
auto spoiler
ADThree R30 rear lip
boost, oil pressure, oil temp, coolant temp gauges
few other bits and pieces...
spending a bit of time tidying things up now.. main focus is the engine bay at the moment..
looked like this when i bought it..
after a bit of cleaning/removing/hiding, its now like this... need to get a greddy plenum to get it how i want it thought.. thats the next purchase
https://www.sau.com.au/forums/topic/268006-rb25-powered-hr31-passage-gt/
  • Replies 63
Posted Images
"what wrong with 235/45R17's on a 17x9?"
I guess nothing but for the fact that 235/45 are designed to go on 8's but you choose to stretch them over 9's exposing the tire walls & wheels to anything that comes along!
And the correct size for your 9's is 255/40
As you say ................. what wrong?
For me .......................... everything is wrong!!!
i think you'll find a 235/45R17 is completely legal on widths from 7.5" up to 9", with 8" being the apparent optimum width.
not to mention a 235 is the largest tyre i can fit on those rims without having issues with rubbing etc, also from a price point of view they are the best bang for your buck.
so in your opinion it's too small, and you don't like my wing.. that's fine, i setup my cars how I like them, and if other people approve, then that's just a bonus.
ps, can you please point out which part of the rim is exposed in the below picture?
Let's see ........................ everything outside of the wheel protection bead, that really, is now doing SFA because the tire has been stretched to it's legal MAX!
Tell me this, WHY would you want to put a tire designed for 8" wheels onto anything more than 1/2" bigger when it stretches the sidewalls as you have?
im thinking that mitchy has gone with a Jap streeter style, in which rubber stretching is pretty common....
the engine is nuts, the coar looks liek youve put some effort into it, the sparcos are sweet..
but from a practicality point of view stretched rubber is a 'looks' thing.
im sure that if you were to take this to a track or strip, you might not be running this rim/rubber combo
as shown today at wakefield, street tyres start to disintegrate and go soggy, eventually loosing 2 sec per lap on average
this stretched tyre thing is for style and looks period... on a looks standpoint congrats!
as your an ACT drver by the looks of things I might end up seeing this in the flesh
from the last pic they dont look THAT extreme!
Pull your head in mate, you've made your point. He's already pointed out thats the widest he can go without the tyres rubbing - and afaik the wheels came with the car, perhaps we should pass on the original owners details so you can send him an email preaching your opinions on tyre fitment?
Btw if you think that's stretched you've got your head in the sand.
mag86 - i'm actually in WA, the car came from ACT, you might see my old legnum super vr-4 over there though. :banana:
ghostwhinger - still going? wow, you must like your bulging tyres/muffin tops.
i don't know about you, but i wouldn't even consider a 235 to be 'stretched', as you can see the rim is contained within the tyre...
Mate that is a sexy car - i think anyone with an R31 should be aspiring to that.
Ghostrider you sound like the JOHOVAS WITNESS of car modifiers - your entitled to your opinion and belief but honestly... get over yourself. Hop on your pushbike and knock on someone elses door.
Car looks mint, and all goes together well, doesnt look mis-matched like a lot of the other modified cars getting around.
nice line man, should go 215s..
i tried 215's and 225's on the front as the 235's rub under hard cornering, the 225's looked fine, 215's looked a bit too stretched for my liking.
ended up back with 235's all round though.. they are cheaper than 215/225's, and it only just touches the guard (which has already been rolled) on hard corners, so there is no damage to the tyre.
it's only because its quite a wide and low offset rim (9" +15) that it rubs, but i love how it fills the guards.
215/45R17 on 17x9
to the guy who says 235 on a 9 inch tyre is wrong,
these are my rims, i have 235/40 tyres on 9.5 inch rims with no problems what so ever.
so umm you're wrong pal, little bit of stretch not only looks awesome but allows you to fit nice rims on your car
Edited by inthisglass
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
