  • Replies 240
Posted Images
Sounds good Brad, bit of bad luck but sounds like you still had a ball.
I spoke to Brian tonight and he has e-mailed me through all the regs and paper work so i am going to try and make it to the Wakefield Park August 2nd and/or the Wakefield Park October 25th rounds.
Very excited. I will hopefully be in the combined sedans.
Chris you definitely need to give this a go next year, You to Ando i see you watching.
Yes watching and considering :P Just got to do the sums and see if it is a viable option this year... maybe try to get out there in Oct!!
Im out for the 2nd August - I want to give OP GP a go as much as I can before it closes :D
Also the last round of MRA is in December at OP!
I actually spoke with Brian Walden, he called me today, so Im on the mailing list now for MRA :P
  • 1 month later...
Just wanted to bump this thread.. :P
Round 3 of the MRA Series is coming up on the 2nd August at Wakefield Park... Spots are going fast so anyone wanting to enter starting thinking about it now!
Please contact me if you want any further information or check out the website MRA Website
Great form of cheap fun motorsport!! Come on guys get into it!!!!! :)
Cheers
Jess
Cheers for bumping this up jess.
I just sent an email off regarding the regs / class eligability for my car ;)
No worries!!
If you dont get a reply back soon let me know and I can help you out getting the info!
What is the car by the way??? Do you have a cage in it...
yeah will do.
ts a r33 gtst - no cage as yet...I dont wanna get one yet untill i find out what I need
Just a bolt in half cage is surfice as you would be going into sportscars class I reckon .
"Roll cages must be fitted to all cars that are competing in a competition event. Alloy cages are acceptable on cars built prior to 2000 and cars built after 2000 will have to have a steel cage. Full roll cages are mandatory for the following classes. Sedans category all class’s. Mini category Group “N” class may run as a minimum requirement a half cage. Clubman class cars must have fitted a half cage with the main hoop above the driver’s head as a minimum safety requirement. "
Seat belts/harnesses are acceptable if presented with no tears, broken stitching or signs of stretching. Buckles must be in good working order and push button attachment type belts are not acceptable . Seat belts must comply with the FIA 8854/98 or SFI 16.1 A minimum of a three point harness is mandatory but a greater point harness is recommended. Seat belt anchorage points where the original manufacture pick up points are not used must have a plate size minimum 50mm x 75mm and 3mm thick
I wanted to do this round but theres a supersprint same day at OP GP which I cant miss!
Aww I know...So spewin its on the same day!!!
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
