hey all
went down south this weekend and was suprised at how my fuel consuption went.. went from carine caltex to capel and then back to the same servo and did some quick math and got 9.8L per 100km. sure this comprised of majority off boost driving but when i drive around too and from work i am almost using 55L for 350 km (15.7L/100km) and that is also off boost drivng apart from 2 WOTs on the way home (onto ried and freeway) and when i drive with a bit of boost i struggle to get close to 300km.
just some "fuel" for thought
pardon the pun
Dan
https://www.sau.com.au/forums/topic/268281-98l100km/
  • Replies 44
daniel, why is your fuel so bad?
should be getting at least 400 to a tank
I'll be lucky if i get 300-350kms in city driving in my r33....
I dont drive off-boost all the time, but even if i try to actually drive nicely in city driving and get as much out of a tank, i'll still only get 350kms max....
Anywho, my car needs a tune....
https://www.sau.com.au/forums/topic/268281-98l100km/#findComment-4572329
Check your boost guage. I have two seperate ones that run seperate lines. They both say -13psi when crusing at 100km in 5th at like 2700rpm. That is not ON boost. But if I then accelerate, because its high enough rpm for my turbo tohit full boost by 3000rpm. If u slowing push in the accelerator to hold a speed, then it will not be on boost, so hold it there to cruise. BUT if you accelerate hard and slowly let ur car come to a constant speed, then it will be on boost more so like -9psi, and u will hear ur turbo.
An engine is designed to accelerate. But if u want a constant speed it is throttled (less air is given) so it doesn't speed up. Hence crusing.
https://www.sau.com.au/forums/topic/268281-98l100km/#findComment-4572856
yeh i have no idea aye its def due a retune. its been 2 years.. i have tried all the other little things like o2 replacement i have a cat the only fuel mod i have is a pump on standard injectors and reg.. hmmmm
so me usage isnt as good as i thought.. bummer
https://www.sau.com.au/forums/topic/268281-98l100km/#findComment-4573353
i done a check on mine a couple of days ago and getting 12.5l/100 or 400ks to 51 ltrs. alot of traffic driving. im pretty happy with that. hopefully it wont change to much when i fit the 600cc injectors and PFC and wind the boost up. (hopeful thinking). still running the auto diff, think that is 4.3 too
Edited by Pal
https://www.sau.com.au/forums/topic/268281-98l100km/#findComment-4573958
change your oxygen sensors if you want better fuel economy ppl! if that dont work, flow test your injectors and repair/replace if neccessary, my r33 averages 420/430km to 50L of city driving and im on boost alot, pretty good for a 6 id say
my s14 would get 500kms to 50L :P
https://www.sau.com.au/forums/topic/268281-98l100km/#findComment-4575113
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
