ok, here's my situation:
Did an RB20 build couple years back, all freshened up Rb20, all brand new internals bla bla bla, with an N1 oil pump. The first yead it went great, no major breakage, did 11.07 at 128mph.
The second year (last year) dropped it to 10.89 at 131mph, but with a major oil pump drive malfunction,
So this year, went and bought a collar, had it installed on the crankshaft. Again went with a N1 oil pump new from Nissan. Did my best so far, 10.42 at 125mph. And again lost oil pressure completely, dismantled the rb once again to fing my ''less than 20km of use'' N1 oil pump destroyed!!!!
So here's the questions to the knowledgeable people on this board:
1- Can dropping the clutch (engaging it) at 7500rpm at the launch make the ''little slack between the collar and oil pump drive'' break the pump?
2- Is there a miracle recipee (specific collar with specific oil pumps) out there that can permanently cure this problem?
3- Is it an actual oil pump drive problem or a balancer pulley (vibrations) problem like I heard from shops near my place?
4- Anyone had this problem before even with a collar?
thx for any info, and please, if you don't know the answers, please don't post anything, even if you want to tell me that there's other posts like this one.
regards
Sylvain
Edited by FastRB20
For starters, using the N1 pump for serious drag racing is not the best of choices.
TOMEI or JUN pumps are far stronger than the N1 pumps.
Then again those pumps can fail if not properly mated to the collar.
A crank that is not finely balanced will also cause you problem.
I used an N1 oil pump on my 10 second GTR for years...it survived lots of 8000 rpm launches by my wife Stacey and quite a few 9000rpm launches by myself. We turned the launch rpm up to 9500rpm and used a hard cut ignition rev limit as opposed to the soft cut fuel rev limit we used previously and it broke the 2nd pass we ran it. Running a properly balanced
engine assembly and using proper crank damper will help it survive.
lesson...use a soft cut rev limit, use a sensible launch rpm, properly balance the engine and use a better harmonic balancer.
Edited by DiRTgarage
Agreed!
Whilst the pump might have a weakness, its as much about how you actually treat it as opposed to anything else.
Hard/sitting on the limiter is BAD and will destroy a pump, hell you can kill a JUN pump in the same way if you abuse it.
rb20 - 131mph
FARK YEAH!!!
now ive got that done with
if u want the best of the best (for non external pumps) go tomei pump with collar and ati harmonic balancer
a little bit cheaper but still fairly good go a jun pump and ross balancer
or just go all out with a external and you shouldnt have any problems (will be expensive)
You should be able to set up a wet sump external pump for not a great deal more than using a jap brand name pump. As the TOMEI pump is around $2200 aud. You can buy a peterson 5 stage pump for less than that so I would imagine that a 3 stage pump would be relativly cheaper again. Add in associated brackets and a bit of fabrication on your stnd oil pan and I would think that this could possibly even end up cheaper to set up especially if you are handy with fabricating some of the stuff yourself. and hey presto no more broken oil pumps. As it seems that your set up is for drag racing it would be quite easy and not going to pose you any danger to set up an engine kill switch that is refrenced by oil pressure to save the engine should you lose a belt etc.
yep
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
