Hey all,
Looks like I just spun a bearing in my R32 GTR, so I am either going to sell it complete or part it out and sell it, Cant be arsed going through a rebuild ... again.
Will post pics later today,
Interior complete, infact whole car complete at present.
Open to offers. would like 15k for the car complete but open to offers, otherwise let me know what you are after off it and we will go from there.
Heath
https://www.sau.com.au/forums/topic/268811-r32-gtr-complete-or-parting-out-eoi/
SOme details on the car? I am guessin black? But could be interested on the complete car. So what i need to know is
Currently registered, until when
General condition of car?
What year model?
ABS?
Mods/wheels/brakes/ECU/turbos/shocks?
Hey guys, here are the photos, you will have to excuse my photography.
The OD has over 70k on the clock however it doesn't read accurately so was probably wound back in a previous life.
The motor was rebuilt only about 6 or 7 thousand K's ago, just enough time for one service... it has a 33 crank, N1 oil pump, tomie head oil restrictor, tomie sump Baffle kit, new timing belt of course, and so on Also the turbos were hi flowed and steel wheeled just before I bought her, although I never boosted above 6 pounds because I could never work out how to use my boost controller :))
Adjustable coil overs : brand is NFU or something by memory they made for a stiff but excellent ride.
Condition of the car is good all over other than a bump some as swhole but in my rear bumper wich marked the left quarter as well, otherwise the interior is in good shape all vents intact :O... the gear nob is worn though and the surround that goes around the stereo and shifter got cracked a little while back :sick:(
The car has 33GTR rims,
a MINES ECU
GREDDY boost guage and HKS EBC controller
and a turbo timer.
and Nizmo strut braces front and rear.
also a 3 inch zorst all the way through.... flowy but a but loud for my taste to be honest.
The car is mechanicly excellent accept of course the bottom end of the motor, I will pull the motor this week I think to see how bad the damage is and if the crank is salvagable or not.
Anyway, any other questions please fire away.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
