R-SPEC Posted May 7, 2009 Share Posted May 7, 2009 (edited) as above i have 2 different types/specs of coilovers. 1 is height adjustable and the other is damper adjustable the height adjustable ones are leaking so i wanna take out the the springs and tops off that set and put them on the other non leaking set i wanna swap em over because theyre too hard for street use so the question is, is it ok to change springs/tops over on different shocks? any help would be great Edited May 7, 2009 by R-SPEC Link to comment https://www.sau.com.au/forums/topic/268932-swapping-springs-over-on-coilover-suspension/ Share on other sites More sharing options...
_Ryan_ Posted May 8, 2009 Share Posted May 8, 2009 are the springs the same dimensions? and they are going onto the damper adjustable shock correct? therefore, swap+soften? Link to comment https://www.sau.com.au/forums/topic/268932-swapping-springs-over-on-coilover-suspension/#findComment-4582661 Share on other sites More sharing options...
R-SPEC Posted May 8, 2009 Author Share Posted May 8, 2009 the springs on the leaking coilovers are wider on the top than the other ones hence why i'd be also swapping the tops the idea of it is to soften the ride + lower it a bit Link to comment https://www.sau.com.au/forums/topic/268932-swapping-springs-over-on-coilover-suspension/#findComment-4582731 Share on other sites More sharing options...
badhairdave Posted May 8, 2009 Share Posted May 8, 2009 yeah, you can do it easily enough and as you are going down in spring rate you will probably find that the damper is better able to control the spring. You may have an issue with swapping tops over if the shaft on the shock is a different diameter or the section for the mount is longer/shorter but you won't know that until you have a good look. Link to comment https://www.sau.com.au/forums/topic/268932-swapping-springs-over-on-coilover-suspension/#findComment-4583537 Share on other sites More sharing options...
