im not quite sure why you guys want a speedo that goes to 300kph. i dont think theres a track in aus with a long enough straight to reach that speed in a stag. id think 250kph would be more than enough for a stag here.
I would have made it 320km/hr but it would be too crowded. The stock 180 speedo is ridiculous so what to choose? 240 or 280 would be enough in most circumstances but 300 should suit most everybody. Its not economical to make a range of different maxima so I settled on 300.
Sigh, I need to remember to look at this while at home so I can actually see the pics!
Got a part number for the Jaycar adjuster?
Speedo correcter Mk II KC-5435 (plus box HB 6015)
  • 3 weeks later...
Probably easier to get the kit from Jaycar but if you do find someone who can reprogram you speedo head let others know as apparently it takes a while to work it out but once done can be easily replicated.
  • 8 months later...
Ok reviving an old thread as there are issues with the site and I can't post in the for sale section. I have bought three Jaycar speedo corrector kits as they are being discontinued and I am able to offer a 300km/hr speedo kit consisting of a dial face, the Jaycar spedo correction kit (requires assembly/soldering) and the isolating washer mentioned in the simple wiring instructions I have found to make it all work for AU$99 posted anywhere in Australia.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
