Hey guys,
I need your help once again. Blew my turbo. Drove it hard on 13psi and blew it. Im pretty sure its the turbo as the boost doesnt spool up+noise.
I need to fix the car asap so i need quick help, don't have time for much research that's the reason for starting a new thread, sorry.
What im after:
-turbo that's an upgrade, better than my stockie but doesn't need to be 1000hp either, something medium power.
Can also someone suggest me where i should look for a turbo/what shops/wreckers are good to call and check out?
Also, good workshop for the fitting of a new turbo, suggestions please
Im basically wanting to make about 240RWKW.
-so please if you have a suggestion, ill be keeping a close eye on this thread and all help is appreciated.
So i need:
Turbo recommendation:
What shop wreckers to check out:
Workshop to fit:
Thanks heaps, ADIS.
https://www.sau.com.au/forums/topic/269122-just-blew-my-stock-turbo/
http://www.skylinesaustralia.com/forums/To...rb-t231635.html
Read that firstly, will save you a lot of money, secondly look in the for sale section for a hi flow, they are a direct replacement and will get you around 250rwkw with good response.
Thank you for your reply. Hi flow is good option, but ill give other turbos a bit of a thought and ill make my decision in next couple of days.
I think the guys are RE customs have a nice Apexi turbo for sale for around $1000 which will make the power you're after. Call Mick or Ray on 9548 3414
Thank you-will give them a call first thing Monday.
Fellas, please don't be shy with your suggestions, what ever you think i should try let me know please as i need to make a decision very soon. Pm me or write here or sms/call 0421 864 698. Adis
Im 50/50 on maybe getting a bigger sucker or just going the easy option and hi flow it. In saying that, im not sure if i should buy one or hi flow mine, and what shops to call.
Thanks.
roughly what size? comparable to a GT30? or smaller?
Edited by Ryan1600
I suggest you get a bigger turbo not a high-flow Turbo.
Yes, I have a high-flow and I'm making 235 kw and it's really responsive - but you will find soon you want more power, e.g. 300+ and you will have to get another turbo soon. You sound a bit power-hungry, so I suggest you go the bigger turbo now...the GT30 is a good size in my opinion.
Bro you are probably right, i will get power hungry but you gotta draw a line somewhere. For bigger turbo ill need to spend extra 1k. plus labor for fitting turbo, plus full ecu,plus tune, plus injectors, plus all other shit, to be honest i cant afford so i have to be happy with 230 kw or so. But you are right, ill get used to it and ill want more...but i better not. f*k its like a drug lol
Kevin, how bout i buy your hi flow and you get ur self a gt30 :down: deal? haha
the stock afm is able to max much lower than 230rwkw
ive seen max and i have 190rwkw
you can still tune with it maxing, and its important to note when it maxes
maxing at 6500rpm means nothing, maxing at 3000rpm to redline
just means it runs like a map sensor and its annoying to tune
still workable, just have to juggle load points
its typically accepted that you replace it past 200rwkw
to ensure you use as many load points as possible, which makes for a better tune
bahhh 190kw? cmon man, are you kidding? firstly let's exclude afms that have been found in the local river, and we'll also exclude spaz engines/ecu's that r&r at 10psi (other issues at play here)
then we can assume, under normal circumstances, 230kw wouldnt be a stretch.
Edited by Munkyb0y
bahhh 190kw? cmon man, are you kidding? firstly let's exclude afms that have been found in the local river, and we'll also exclude spaz engines that r&r at 10psi (other issues at play here)
And then we exclude "happy" dyno's and we are back to 200-210
lol well that was a nice round trip :)
but i'm sticking to my 230, happy dynos or not.
edit:
anyway, lets tell the guy what he wanted to know. which turbo.
hks2535 or gt-rs. buy a used one, if on a budget. either of these is my pick over the highflow.
Edited by Munkyb0y
LOL, well i did get 223rwkw with the standard ecu, i then put in the pfc and had it tuned and got 210, i know the 220 was a happy dyno and the 210 was on a dyna pack which are known to be a little conservative.
ahhh so a little conservative, and a little bit happy, evens out at 220 in your case. we're getting closer lol
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
