Last night i was doing a photoshoot of my car and my waterpump decided to go bye bye, it only just started leaking a bit so i am going to change it, does anyone know where i can get a waterpump from???? i dont need a timing belt service kit as i changed all my belts and water pump 40k ago on the motor. and would anyone have the genuine nissan number for the water pump????
to suit
1995 R33 series II motor
Edited by slverbullet
https://www.sau.com.au/forums/topic/269295-rb25det-water-pump/
Tweakit in Mona Vale sell RB25 water pumps for $80. Not genuine Nissan, but it's the same brand pump as my mate runs in his drift 180SX and it hasn't skipped a beat. Click here for Tweakit's website thingy.
If I where you I'd change the timing belt regardless considering you have to remove it to get at the pump anyway, but that's just me :D
Didnt you guys read his questions? he specifically asked for the OEM Part Number with X3 question marks "???"
lol
anyhow
the Oem water pump number is 21010-21u25 for ALL......
The original poster seems so upset that we missed that part... oh wait!
thanks mate i will pick one up from there sometime this week, that is cheaper than everyelse that i have found.
not that i was trying to offend
but its just that ive noticed some people try and sound like they know what they are talking about but reply a message/2cents just for the sake of it or just to be heard about...
especially technical side of things, most replies are just half arsed...
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
