G'day all!
I've recently brought a slightly done up R33 GTST T25 . 95 skyline and absoloutly loving it! Only thing is, is i don't know exactly what's been done to it and want to know. I know it's got a bit of turbo work and a nice big HKS front mount and Plazmaman piping and a new heavy duty clutch... but he didn't have papers for any of it. I know that's suss and all but i couldn't resist buying it.
Anyway, i just want to know a bit more of what i've got and what i'm running. I'm a bit down on knowledge for cars these days so any imput or comments would be great.
Cosmeticly she needs a tad of tlc but i will get to that in due time... when i've got money haha.
https://www.sau.com.au/forums/topic/269648-newbie-with-an-r33/
Hey man im a similar situation as I have just bought an R34 GTT and the dude i bought it off told me hes had the turbo high flowed but im not sure how i tell if its really done, other than pulling the thing apart which im not experienced enough to do :D
Yeah i'm only on my L's at the moment. Had a bit of troubles being able to go for my licence. I can go for my p's now but why do that when i wouldn't be able to drive my baby? I'll just stick with my L's for the moment. Until i can take out the turbo i guess.
hahaha, this is fkn funny. Sorry dude to laugh at your expense but who goes and buys a turbo car and then thinks they can take the turbo off and vic roads will go "arrh ok well if you have taken the turbo off i suppose it's all good, just make sure you don't put that nasty turbo back on again!"
Thanks Joshington that was one of the best laughs I've had in a while. Hope you get it all sorted.
Just FYI as well Joshington, there was at least one other thread started recently about the same thing, basically the car's build plate will say that it is a turbo, and that in VicRoad's eyes means that you can't drive it, even if you happen to take the turbo off. (not to mention it's an incredibly daft thing to do lol)
yeah sounds like he jumped the gun....... couldnt wait
the best thing is to sell the damn thing....... go through all the P's....
and then buy something better in the end
you wont regret it in the end
That gave me a good laugh!
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
