depends how bad they are, when i first bought my car they weren't too bad, but noticeably yellow. i just use carnauba wax from mothers, i got a clay bar, small bottle of wax and instant detailer for around $30 from autopro, dont sand them unless they're really really bad and clearcoat them or something, i did this on my mazda and they turn yellow every few days now. heres a pic of the wax i use (on the left) vdjspf.jpg on the bottle is says 'removes oxidation' which is that yellow shit. this stuffs pretty good, i wash my car once a week and i only have to wax my lights once a month, all u need is one quick coat which takes 2 minutes.
heres pics when i 1st got my car
and heres pics now
pics arnt the best sorry, they wernt taken for the headlights, there just random pics on my comp
Edited by jimmys-33T
PM N1GTR he was having a group buy thing for head light reconditioning that was ment to run until june i think but had to shut it down early... it was going to be like $140 ish i think from memory but was a pro job and would take about a week in sydney.. he could prolly give u a number to fix it up for good. or i use mothers plastic polish works a treat and lasts about a month or so
GlassyLite!! i bought it at a car show last year as a last resort before i bought new headlights.
mine were as yellow as an old mans teeth that smoked a pack a day for at least 30 years. then come up very clear.
i don't really have any before or afters but highly recommend!
http://www.glassylite.net.au/webspecial.htm :P
so do you take out the headlight and clean the inside or just scrub the sh*ts on the outside?
With GlassyLite its like a cut n polish but for your head lights. It comes with real fine sandpaper to get out the real cruddy stuff which you sand with running water on it, then apply cleaner and shine followed by the sealant. all done on the exterior!
hey guys,
what can i buy from where for how much and what would i have to do with it to clean the gross murky look of my headlights
thanks,
Andrew
check this out as an idea.....the 2nd pic is after glassylight on the drivers side only b4 they put on the crystallite (tint)
http://www.skylinesaustralia.com/forums/in...t&p=4552606
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
