  • Replies 227
double demerits?
huge turnout?
I might steer away actually.
I'd not a big fan of yellow stickers, I'll see if i get around to lifting the ride height abit before saturday.
Out of interest is it gonna be heading north or south? Just so I can break off if it's heading north and head home rather than go back to the city and that.
You're not going to get a sticker or a fine if you're behaving ffs
I've never seen cops come to a cruise meetpoint and actually get out and look at peoples cars.
lol yes you have, about a year ago at baldivis (think thats what its called, the shopping centre at end of freeway south)
i think that with the additional countermeasures that are being brought, uhf and radar detectors if the popo try and add their own decals to our rides they aren't gonna be able to do more than 2 without multiplel unmarked cars which are easy to notice and split.
My car is stock... I just wanted all the cops out there to know that my car is stock. Actually it's very hard to find after market parts for Skylines and I don't think anyone here has anything remote suspect about modifications other than the odd brake and tyre package which adds to stopping power only, am I right or am I left?
you are centre =P
bringing out the almighty bummble bee for first time since finished at shop still a few things to go see how much i get done today but either way ill be there come say hello its orange with carbon bonnet n boot believe me u wont miss it
You're a funny guy. :)
Guys, I don't think you have anything to worry about tonight. Was on an impromtu antilag cruise last night and one of the boys got pulled over by the boys-in-blue. They had a chat to him about car crushings, lectured him on speeding, complimented him on his car then sent him on his merry. Cops are on strike this weekend and are thus refusing to invoke their right to inspect cars for defects and so forth. Not only that but they are also parking their cars IN FRONT of multinova's with their lights on to "check the welfare" of the multinova operator. So, suffice to say, I don't think that anyone has ANYTHING to worry about tonight unless they are going to be complete tools. Heck, last night even had a chaser dragging off a commodore, cop car a few cars back and didn't do a thing. Stupidity still reigns, but the cops aren't doing anything about it at the moment. Don't stick out like a sore thumb and you won't get hammered.
See ya'll at the meet tonight :)
-Chris
i can back this up i nearly crashed when i saw it lol i was like wtf are you doing? the xtrail parked directly infront of the camera with his parkers on.
get last weeks west for those that want to read the article about it.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
