i know theres a few threads on exhaust here but im going to do an exhaust on the 260 shorlty... im just wondering what i need? dumps, front pipe, and cat back... ive gutted my cat already. do i want the split dumps from just jap?? its 399 i think for them and 299 for the front pipes?
cheers :whistling:
ps i think the jap styling with the 260 may need a cannon but im not 100% keen :S im really unsure what tip i want? twin tips maybe?
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/
just had my front muffler removed today and replaced with a straight pipe.now it goes- advance dump/front pipe,gutted cat,straight pipe to a magnaflow cannon.sounds lovely and decibel tested it at the workshop,it made 92.8 @ 4000rpm.very happy with it now!
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4592533
cheers :)
There is nothing wrong with the JJR dumps and front pipes, there a copy of the HKS ones and are fine, just make sure the flange face is flat before fitting.
A mate had a set on his 32 GTR with 2860-5's, fitted up fine, with JJR front to, did 455rwhp @ 20psi, so worked fine to.
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4594779
If you do a search on here quite a few people have mentioned that the stock GTR dump pipes are quite good. My 260RS has stock dumps, 3" Apexi front pipes, 5" cat, 3.5" cat back with 2 mufflers. The rear muffler is a Fujisubo Jasma cannon. It has quite a nice sound and is not too loud.
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4595631
JASMA = less than 95dB
So depending on where you live, this can be fine or could cost you an EPA fine and a defected car (like in Victoria :P )
Edited by iamhe77
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4595819
cheers :D
I have the dumps and front pipe for less, front pipe is used like new and dumps are unsed.
pic
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4597888
So depending on where you live, this can be fine or could cost you an EPA fine and a defected car (like in Victoria :blush: )
Awesome. I did not know that. Hopefully with the 2nd muffler it would be under the limit.
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4598539
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
