i know this is a stupid question..
but im not 100% with cars.
just wanted to know what this part is?
if its cut like in the photo is it repairable? would i be able to hide it somehow? or make it look neat so it doesnt look cut? would it be defectable? cheers.
**this part holds up the radiator** and seems to be goings straight to the front bar..
my intercooler is abit to long and its got a cut on both sides that only goes about halfway, so its not all cut off.
Edited by wannabeer33
https://www.sau.com.au/forums/topic/270266-whats-this-part/
From that angle it looks like the reo bar has been cut off its supports, can you get a side on view?
yeah, ill take a few more photos in more detail later on today.
from further studdies it looks like the reo bar.. because from what i gather you can unbolt this part off.
ill get more pics up.
https://www.sau.com.au/forums/topic/270266-whats-this-part/#findComment-4598025
if it is the chassis rail, what kind of work am i looking at? how much money am i looking at paying? how long? etc..
is there a wrokshop here in adelaide that can fix it? just wanna know more details. cheers.
or is it hideable?
https://www.sau.com.au/forums/topic/270266-whats-this-part/#findComment-4599423
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
