AS V-Spec said tyres and suspension setup have the biggest effect on this. Power delivery also has a part in this but not as much as the other two factors. My toyota has less power than my skyline (226rwkw) but when i had my slightly worn dodgy pirellis on it and very stiff suspension it would snap sideways and wheel spin in 3rd on dry bitumen as soon as it came on boost at about half throttle (~3000rpm). My skyline with drag suspension rather than drift setup has a big turbo (gt3037s) and very soft falken tyres but doesn't go sideways and wheelspin when it hits boost as easily as my toyota. You can put very stiff suspension in a silvia/180 and setup camber and caster for drifting and get it to wheelspin easily in 2nd with relatively stock engine.
If you are just wanting to know how much power your car has as vspec said go to a dyno shootout or something (pretty cheap) or if you want to know how to get your car to do this just speak to a tuning shop and they should be able to advise what mods are needed.
Jamie
i have a rb20det in a siliva.. heaps of camber on the rear.. low n hard.. and if i go from first two second i get no traction what so ever in second and it wil chirp and sometimes with .8bar boost it will kick a bit sideways changing to third... with 1bar it will kick out and spin a lil more but thats with 4.3 diff gears i think.. well at 110 in 5th its about 3800!!!
lol...
i have over 200rwkw.
no loss of traction in 1st or second, if i launch smoothly and then mash it.
If i launch hard then wheelspin all the way till the top of 2nd.
I only have 225's so it does well to keep traction most of the time
but it all has to do with how you work ya clutch
With my SR180 and 195's i could wheelspin at 110km/h for as far as i wanted in the dry (i got a fine on the highway within 20mins of driving with those tyres :( ). Tyres make a phonomenal difference i had 2 difference sets of 235's, once were pathetic and would spin for a fair bit when i shifted into 3rd, while the others would just twitch and hook up well.
To answer your original question i would say 220rwkw with a stockish suspension/tyres setup.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
