PRICE: 500 firm
Suits: r33 s2 (manual), not sure about what other models it suits.
I have Mines ECU for sale. Its programmed to run best on basic mods and stock/hi flow turbo. When i got this ECU, it gave me 30% extra power. Top end opened up unbelievably. The ECU is plug and play and im willing to let the potential buyer test and than make up his mind on weather its worth his money, im that confident in this product.
Here is my dyno graph to prove, all with basic mods, running with no problems, exhaust, pod, cooler,12psi.
Mines ecu maintains all the safety features of the stock ecu.
If you intend to keep your car with only basic mods, (exhaust, pod, cooler etc) than this is ideal for you, i guarantee it.
Other benefits: (there may be some other tweaks I don't know of)
1. Removed the Speed Limiter
2. Reset the injection and ignition timing
3. Expanded the rpm from 7700 upto 8200 within the Rev Limiter
4. Richer maps to handle hi flow turbo + breathing mods + handle more boost
5. No wiring/tuning needed
6. Safe AFR's
Selling due to Turbo/fuel pump etc upgrade, simple.
PM/sms 0421 864 698 Adis.
https://www.sau.com.au/forums/topic/270378-mines-ecu/
I cant do too much about the price. I believe its reasonable price to ask and i think who ever gets it will be very happy. Im offering 'try before buy' because im that confident (provided you have the right set up).
When i was doing basic mods to my car, this is the only mod that put a smile on my face. Exhaust, cooler did lil' bit but i wasn't as happy.
https://www.sau.com.au/forums/topic/270378-mines-ecu/#findComment-4599546
Im looking for 450 at least.
I have one offer of 400 so ill keep R33SII25T in mind if i do decide to sell it for that much.
I also have 450 offer but the buyer doesnt have the money yet so, STILL for sale.
PS: i would be most happy if potential buyer checked it out in action first, easier to sell that way :-)
https://www.sau.com.au/forums/topic/270378-mines-ecu/#findComment-4599612
Please correct me if im wrong but if it has a richer map doesnt that slightly defy the point of a tuned ecu? I thought the idea was to go leaner but within the limits. Sounds like alot of black smoke and more fuel consumption. Again, correct me if im wrong, just to clarify it is suited to a std turbo then?
https://www.sau.com.au/forums/topic/270378-mines-ecu/#findComment-4616640
its running pretty flat 12:1's which is a good tune in my book
most of the std computers dump the fuel in when you crank the boost, and the afr's hit 10:1 or worse
https://www.sau.com.au/forums/topic/270378-mines-ecu/#findComment-4618471
  • 4 weeks later...
Alrigggghttt, this is BACK for sale.
Reason: After installing the gt3040 torbo, i have been forced to upgrade to power fc.
MINES has to go :)
Like i said best bang for buck for stock turbo and basic modss. Anyone that wants to try it out before buy is more than welcome, as long as im in the car, to see the difference too :P
pm or sms 0421 864 698.
first in, first serve
https://www.sau.com.au/forums/topic/270378-mines-ecu/#findComment-4676797
Stuid question, but how much 'new' is a mines ecu? Just trying to get a comparison to second hand..would be ideal for mine, as would like best performance on 12psi with basic mods, without going to a afm turbo .....thanks guys
https://www.sau.com.au/forums/topic/270378-mines-ecu/#findComment-4676931
I'm seriously surprised this is still up for sale :)
Before i sold my pride and job, My R33 GTS25t was Making 225kw@ 1 bar of boost with a JPC high flow turbo, FMIC, Turbo back 3'' Exhaust system, Walbro fuel pump, Sard Fuel Reg and APEXi pod tuned with SAFC2..
After purchasing a MINES ROM, and fine tuning it with the SAFC2 on the dyno by my tuner. My car made 242kw @1.1 Bar of boost. may not off made a massive jump in power. But response and top end pull increased massively. Car ran heaps better and it was so much fun to drive =]
If any one wants my Dyno graphs to back my statement up feel free to shoot me a PM.
Seriously guys, its worth it! =]
Adis, why you selling this? keep it! lol
I'm sure if you go to tuners with the ability to reflash ECU's they and retune the MINES ROM as you keep upgrading your car.
https://www.sau.com.au/forums/topic/270378-mines-ecu/#findComment-4681978
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
