I bought an R32 GTR 3 months ago & don’t drive it that often to give you an idea I just filled the tank this week for the 1st time since the 17 Feb when I bought it.
It was running fine up until about a month ago when it started to run at about 70% then I went away for about 3 weeks in that time the battery went flat so I charged it. Then the car was running good for a few days but this week it went bad again & is running at about 50%.
Some of the symptoms are excessive Back fire, missing, popping sounds from the engine like ping or off timing. So far I’ve checked 3 of the 6 spark plugs & it looks to be running a bit rich as you can see from the photos 1 of the plugs is really bad, much more fouled than the other 2.
I thought the problem may be due to the car sitting around for so long & being a tight arse by filling the last tank with Regular unleaded on the 17 Feb (3 months ago)
Has anyone got any ideas on what I should be looking at checking or replacing before I tow it to a tuner or someone who’s going to charge like a wounded bull to change the spark plugs or something easy like that?
I don’t think it’s a major problem so any opinions or ideas would really be appreciated.
https://www.sau.com.au/forums/topic/270443-online-diagnosis/
filling the car with regular unleaded has quite possibly f**ked your car. it should be run on 98 RON premium fuel ONLY. mate if you only do a take every 3 months then it's not like the cost is massive either. remove the shit fuel from the tank (just remove the fuel return and pump it into a jerry can using the fuel pump), and re-fill with proper fuel. buy some new BCPR7ES plugs and check the gaps (should all be 0.8mm). install them and hope for the best.
You do know petrol has a shelf life of about 30 days?
Shit petrol + OLD shit petrol = Leanout and Pinging
The ECU has probably tried to save the engine by richening everything up, that why you could have black plugs, but still cant burn the fuel because its old and shit.
Depending on how much you let it ping and backfire your 50% could be 3 cylinders broken. haha
    • bumping this post as im still having dramas, my fuel pick up is sitting on the bottom of the tank, my pump gets a constant 13 volts through a relay, my fuel pressure holds consistently without fluttering or dropping, yet as soon as im near half a tank of fuel my car starts fuel starving and leaning out, it cant be due to g force as it never pulls hard enough before it starts breaking up, any help would be much appreciated
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
