i need some advice on whats happening to my car. only just bought my r33 maybe just over 2 months now and i've never really fanged it. i did it once and for some reason when i'm boosting it up (almost flooring it), after about 4,500revs there is a surge of power and boosts up more but then it starts to choke/stutter?
today i got my exhaust put in and decided to give it a good fang and the same thing happened. i would boost it up hard and all of a sudden after about 4,500revs there is a kick in the power and it boosts up more but then starts to stutter. as far as i can remember it happened in all gears from 1st to 3rd. i'll test it out tomorow again.
now i just want to know if this sounds like the ordinary stuffed coilpacks problem? or does it sound like something else? fuel pump?
https://www.sau.com.au/forums/topic/270662-r33-boost-problem/
tape your coil packs up and have a go. use good electrical tape. only really need to do it around where they screw into the car. theres a thread about misfiring above 4500rpms,, i used to hav that problem and now it redlines with no problems
thanks for info will try taping the coils not sure how that would fix it but worth a try if it has fixed yours.
vvt switch point, change your plugs first or regap. if it continues to missfire at high rpm then buy some second hand coil packs and switch them in/out until it stops happening (or just buy some splitfires). tape wont work (poor insulator of heat)... possibly better than nothing
the reason it boost harder after 4500 is coz its a standard dual stage boost solenoid they all boost harder after 4500, the stuttering and coffing is coil pack related. also search for a thread that over rides the second boost kick for full boost from go to wo.
^^shit didn't ahve a clue about that. i'm coming from owning 2 32s so have no idea. thanks heaps
someone show me this thread about getting full boost!
Edited by jakez88
As the previous poster mentioned, your car has a two-stage boost controller as a stock item. It regulates that boost will go up to 5psi at around 3000rpm, and then once you reach around 4500rpm upwards, the boost climbs to 7-8psi.
For reference's sake, I've seen mine get to about 7.5-8psi when I get close to redlining in 3rd gear coming onto the highway.
If you were to install a manual boost controller (like a turbosmart, or gfb as examples) this takes the place of the stock boost controller and sets a maximum boost as set by you when adjusting the new controller. Up to around 10psi is considered safe with stock internals and turbo.
Unfortunately I can't help with the misfire problem, but as others have stated have a look on these forums, I have seen a stickied thread relating to it.
Get a turbotech manual boost tee, there on ebay about 40$, They hold boost pretty good. Mine use to hold up to 10-12psi on stock turbo with full exhaust and front mount. Get that and when you connect it, dissconnect your stock boost solenoid.
    • Nah its a server spammer thing  Although, now that I manually approve all the accounts I can probably loosen up some of the restrictions.
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
    • Thanks buddy. I thought it was a server storage thing. 🤣
    • Perfect! Thanks for this, both look like great options!
