i think they might b abit pricey depend on ur limit go 4 tein i use them on my r33 gtr love them, u can go second hand wich will save u money but may only last a month u neva no. call my mate rob at volatile customs 0438469390 hes is based in morley tell him neil sent u with the 33 gtr he will look after u. good luck let me no how it goes
https://www.sau.com.au/forums/topic/270727-coilovers/#findComment-4603614
echo
dan please if you have nothing else to contribute to the topic or :blink::D
while on topic about coilovers... whats a better option. bilstein/koni shocks with lowered springs or teins superstreets,JJR D2 coilovers,etc? coz shocks and springs installed i got quoted 1700 for bilsteins and 1900 for koni's-damper adjustable.
https://www.sau.com.au/forums/topic/270727-coilovers/#findComment-4606123
I would go Bilstein over Koni in a Skyline.
I have the Bilstein PSS9 coilovers at the moment. There is 1 kit left and if another forum user doesnt purchase them soon, they will be available.
D2's, i wouldnt touch them. Id rather waste the money on beer than cheap china suspension parts. :blink:
Super Streets are also very good, however with the exchange rate at the moment, they will be close to $3000 mark.
https://www.sau.com.au/forums/topic/270727-coilovers/#findComment-4606162
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
