so do u just cut liek a square of a bit of can then do the bolts up and sandwich it in between?
good results?
its simple.
get any metal, cut it into the shape of the flange of the bov, drill 2 holes for the bolts. then put it between the bov and intake pipe.
All it does is stop the bov from venting the air back into the intake pipe, so yes you will get good results
Edited by Kaido_RR
https://www.sau.com.au/forums/topic/270780-bov-question/#findComment-4604291
i love sau, a question is ask then people feel the need to add their 2 cents about why they think its gay or similar.
it takes less effort to not post or read the topic
1 - It is gay.
2 - If it was meant to sound like that, they would.
3 - If anything, like I said it slows the turbo down unnecessarily & could cause damage to it, so why would you want to do that.
4 - It is gay.
For the record my car has wicked turbo flutter, but that's due to the size of the damn thing & possibly a crappy bov that will be getting replaced soon once I find a decent replacement. That sort of flutter sounds good, not stock turbo spec flutter that sounds like sin.
https://www.sau.com.au/forums/topic/270780-bov-question/#findComment-4604331
1 - It is gay.
4 - It is gay.
your opinion WHICH has nothing to do with the question ask in the 1st post
https://www.sau.com.au/forums/topic/270780-bov-question/#findComment-4604370
For f**ks sake man....
Yes you can put a piece of aluminium can in between the flange connection if you want, so that the air returns back through the turbo just to create a bit of noise.
I can also drive my car off a cliff if I wanted to, but it doesn't make it a good idea. That's my point, I don't give a f**k what you do to your car, but I'd like people to show just a bit of common sense if they are thinking about doing something with a negative impact.
https://www.sau.com.au/forums/topic/270780-bov-question/#findComment-4604395
and your reply adds what to his question?
the flutter he is after is bad for turbo he was advised that and you criticize the guy who points that out ?
https://www.sau.com.au/forums/topic/270780-bov-question/#findComment-4604415
+1
Why damage your Turbo for Wank factor?
https://www.sau.com.au/forums/topic/270780-bov-question/#findComment-4604420
there is no proof that blocking off a bov or running no bov causing damage to the turbo or engine
gazza750; i answer his question, not very hard
Edited by Kaido_RR
https://www.sau.com.au/forums/topic/270780-bov-question/#findComment-4604457
1 - It is gay.
4 - It is gay.
so flutter is gay... EXCEPT if its YOUR bigger turbo? :laugh:
and if its slowing the turbo down, and damaging it like you claim, why do you let yours do it? :closedeyes:
https://www.sau.com.au/forums/topic/270780-bov-question/#findComment-4604735
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
