My right hand rear taillight (the largest one) is not working properly on my R34. It will light up when I put the head lights on however when I depress the brake pedal it does not get brighter.
Because it seemed that the globe was working (as it lights up with head lights) I tried changing the fuse however this did not correct the problem (the one in the engine bay marked "Tail Lights" however upon thinking about it, had the fuse been faulty all of them probably wouln't be operational). So do you think there is a problem with the globe? And if so how do I get to the f*cker? (I opened up the carpet in the boot but I think I may have to take the whole light out somehow?)
Thanks for the help on my n00bish question!
https://www.sau.com.au/forums/topic/270931-tail-light-problem-r34/
It will be a twin-filament bulb - 1 filament for the tail light and 1 filament for the brake light.
The brake light filament has pooped itself. Get a new bulb.
NFI how to get at the bulb, but it probably won't be all that difficult if you look carefully.
yep..globe sounds like its gone..
and correct the whole tail light comes out.. there are a few nuts that have to be taken off... 10mm DEEP socket will do the job perfect..
From my experience - open the boot and remove the lining (secured via some plastic quarter turn screws) - you should then be able to remove the bulb from behind.
I have an r34 4 door btw... not sure if it differs from a coupe....
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
