Wrecking 1998 Stage series 2 most parts available
RB25DET neo motor complete with turbo loom ecu etc 109,598k's $1500
Auto box $500
brake calipers $200pr
rotors $100pr
factory wheels good tyres missing couple caps $300
3 inch cat back exhaust jasma rear mufflet $350
weathershields $100pr
floor mats $100 set
doors $100ea
door trims $70ea
side mirrors $70ea
speedo cluster 109,598 k's $150
steering wheel no airbag $100
window switches drivers $50 others $30ea
auto gear knob $65
cup holder $60
centre console $100
seats $300 set
dash fascias from $30ea
climate control $140
clock $40
factroy suspension $130pr
outer tail lights $100ea (no inners on tailgate sold already with tailgate)
sunvisors $35pr
various trims carpet etc from $5
Plus much more as I have complete car with front end damage. PM me for more parts/prices etc
I am located in Jindabyne NSW but can send parts either post or by courier
Thanks
Daniel.
https://www.sau.com.au/forums/topic/271300-wrecking-1998-stagea-s2/
  • Replies 73
will take all parts as per PM i cannot reply due to inbox settings will PM you when i can
Auto box $500
rotors $100pr
floor mats $100 set
doors $100ea
door trims $70ea
side mirrors $70ea
auto gear knob $65
cup holder $60
centre console $100
seats $300 set
clock $40
sunvisors $35pr
Thanks
Daniel.
i'd have to have a look tomorrow how hard to remove the rear 1/4 windows see whats involved and get back to you.
there is a thread on here some where on how to do it safely. caust the copper wires running into the window can shatter it if your not carful.
and cause my car's getting a respray end of the year. be good to have back up incase they do the same mistake. and i have to get clear ones
ok will have a look for thread..is it something to do with heating wires up.
will let you know how i go
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
