You moron; if you read the title, you'd realise what you actually want is steel without
STAN'S.
I didn't see that, I will have to replace my current order with Stanless steel for the extra weight reduction on my Mum's Camry. Thankyou kind sir.
Perfect, I'll take 6. Can you deliver to Pakistan?
It does seem odd that you'd place an order for Stanless steel then request it be delivered to a such an ironically named place.
Still; if said delivery address is as packed with Stans as one would imagine; the inherent lack of Stans in the steel you've chosen, is a wise choice.
Well played.
  • Like 2
  • 9 months later...
  • 1 year later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
