im having alot of trouble trying to figure out what wheels and what color wheels to pick for my Millenium jade R32.4 wide body. any suggestions? pictures would be good cos i can just say gold VOLK GT-C's FTW!!!! but it might not look very good with the color of the car.. so yeah! help please!
heres a dodgey pic it just finished its respray ill take better ones wen the lights are all on.
some wheels in black should look good...not sure on what type...maybe some nismo's
Black wheels look awesome too!
GTRBOS on SAU has black Work Meister wheels (I think) black spokes and silver rim/lip.
Awesome choice of colour! Would of been better if you brought the wheels before you painted the car so you could mod the guards to suit the wheels.
Remember, offset means absolutely everything when choosing wheels. Choosing the right offset can make the difference of making your car look killer or failing beyond belief. Stay away from anything above +20 and you'll be on the right track...
  • 1 month later...
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
