hey guys, i meant to ask if there was a nismo package for the M35 as mine has a Nismo badge on the steering wheel and full set of floor mats. Not sure if you can buy them as an option, but the wheel looks factory, unless the previous owner did a really good job of putting a badge on.
https://www.sau.com.au/forums/topic/271568-m35-stagea-arx/
I have seen a Momo pack advertised on some ARX but not sure about a Nismo pack for the ARX. Can you post a pic?
Cheers
Andy
https://www.sau.com.au/forums/topic/271568-m35-stagea-arx/#findComment-4614354
