Looks like I'm in luck with the ECU, there is only one thing I'm not sure about!
The markings on the ECU read
A56 R12 JA Nissan A56-R12 L18 1Z07 UNISIA JECS CORPORATION JAPAN
Which should be fine assuming the L18 1Z07 is the serial number, i.e. Iain's is L18 1Y03.
The part I'm not sure about is that Iain's is stamped with a little circle and a D7, the one coming back from Japan with my name on it has D8. Could this be a firmware thing? Can anyone get any gossip, maybe it's just the quality control person's number or something?
I've included some piccies, I want to start getting excited that it's right but I'm not 100% sure!
  • Replies 111
Posted Images
i bet you its firmware, plug it in and see if it works dude. if its 100% from a VQ25DET equipped M35, i rekon its gonna work.....
did they mention what year it was from? mines an 01 and im game enough to try it in my car
It's a December 2001, I would like to know it works before I start making arrangements for the remap with SAS.
I may even try it in mine, is it easy to remove the glovebox to get to the ECU?
I've asked Ken if he can get any indication of what the D# is before he departs Japan.
its pretty easy dude, youll work it out, i think its about 6 screws. no need to remove your ecu, just unplug it and plug in the other one and leave it hanging
Just let it dangle eh? Won't do any damage if I floor it with the new ECU swinging on the wire? :blush:
I'm still waiting to confirm with SAS but at this point in time I have paid for the ECU, they were going to reimburse me BUT I've asked if they need the ECU past the initial trial and development stage i.e. my tune. If they don't, like Andy has with the turbo, I will hold the ECU in my possession incase anyone needs one urgently to replace there's, the original cost plus a little extra will be required but I can tell you all that these ECU's are not easy to find!!!!! Even Iain will confirm that we have only sighted one on Yahoo Japan Auction (IM) since we have been looking and I've tried all around australian wrecker's with M35's and those that did have a VQ25DET and ECU would not seperate them.
Anyway, I'll post a message announcing that I will have an ECU on hand incase one of you EManage Ultimate guys fry your ecu :)
I'm hoping to have the ECU in a week or two so I can start arranging everything with SAS.
I'll give the ECU a test run before I take it in just incase anything isn't quiet right.
Is there any way (like via the display screen) to check the revision date etc. of the firmware on the ecu?
I'll looking forward to this remap, should be awesome! Hopefully I can squeeze a bit more out of it than you EManage Ultimate boys :)
im sure youll be able to! no piggy back is as good as a remap/fully programmable ecu.
lets just hope they CAN remap them :)
You'd think because Nissan mapped them to begin with they *should* be remappable :D
I sent SAS the link to your pics the other day, so he can have a squiz at the internals pic.
I'll see how things go when the spare ECU arrives from Brisbane, the ECU's *must* be remappable especially when you have products like the Nismo ECU on the scene, that's probably just a remapped stock M35 ECU.
ok im taking a leap of faith for that nismo ECU. so assuming i win it, ill be selling the emanage if anyones interested. might chuck it in the FS section soon.........
Good Luck! (sincere, not sarcastic :) )
Better get some octane booster unless you want to ping your life away...
detonation can be caused by air that is too hot also as well as lack of fuel. a FMIC will allow me to run more boost which this ECU is already programmed to do!
The boost level is set by the brass insert in the wasegate line, unless you have a boost controller it wont change.
The Nismo ecu would be great as it will speed up gear changes and improve most aspects of the engine but it is tuned to 101 octane. If you cant remap it due to language problems you might need to fit the Emanage to adjust things down, I wouldnt sell it just yet...
ill see how i go for the moment.
boost is ECU controlled mate, there is a solanoid that controls the bypass to the actuator. sometimes its good to retain the factory boost control as it can drop off boost levels in the event of detonation. that brass restrictor slows down how quickly the boost comes on, yes it does affect boost a little. on SR20s if you removed it, you got a psi or 2 more and boost came on a lot faster (compared to factory)
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
