I heard it's pointless, cos as soon as you put local fuels in it, you loose pwr and end up only similar pwr with local delivered ones... and you only have 180 speedo. But I heard the leather steering wheel looks nicer in jap version than the local plastic ones.
Why not start with local S15 and mod it up? at least you got warranty if u buy it new and local delivered ones usually holds its value better...
there is a slight difference. power being the 1st. the silvia badging,.... i think maybe injectors or something, wait for dark to dig it up. oh the reflectors in the rear bumber arent in the jdm and the years 1999 jdm later aus.
id personally buy a jdm spec r over an australian one.
sorry.. i cant find the site..
but its a webpage of someone on this forum, with a fully JDM converted white S15..
i remember, it had a popup dash monitor, and headlight washers, rear wiper.. stuff like that..
different tubro
electric fold mirror
crimate control
A pillar boost gauge
badge
rear wipers
180 speedo
silightly different head light
surprise, u pay less insurance for Jap import S15 than aus. S15 due to the accident rate
and u can have a Jap S15 for high 20' instead of low-mid 30" aus. spec
To summarise:
JDM > AUS
climate control
xenon hid headlights
tv screen/sat-nav/md
rear windscreen wiper
factory boost gauge/a-pillar
180km instrument cluster
fog lights
ignition keylight illumination
heaps more, see
http://www.bengoodger.com/cars/silvia/jsit...s/options.shtml
*tv screen/sat-nav/md
are option but not standard
i read a few aus. magazine when the car release, mention about smaller tubro in aus. spec due to esmissionyep only jap spec
s15s have BB turbos,
ozzy delivered s15s are non BB, but roll bearing turbos..
i GUESS there is no way a factory Jap S15 is tune for 100 octane, so the jap spec should preformace 184kw in aus. fuel
Originally posted by HKSgtst
i'd get a Jap spec one. As they are cheaper, more powerful and rarer.
But nowadays S15s are everywhere. oh yeah, its hard to find a good condition jap spec S15.
you'll make the savings buying a jap spec model, but you'll end up paying it all back or even more to insurance...
oz delivered s15 are heaps easier and cheaper to insure
not really
someone found out that Jap spec is CHEAPER to insure due to the accident rate of Aus. spec is so high.
It is cheaper to insure a Aus spec S15, Im sure of it having been on the silvia forums for awhile.:uh-huh:
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
