I heard it's pointless, cos as soon as you put local fuels in it, you loose pwr and end up only similar pwr with local delivered ones... and you only have 180 speedo. But I heard the leather steering wheel looks nicer in jap version than the local plastic ones.
Why not start with local S15 and mod it up? at least you got warranty if u buy it new and local delivered ones usually holds its value better...
there is a slight difference. power being the 1st. the silvia badging,.... i think maybe injectors or something, wait for dark to dig it up. oh the reflectors in the rear bumber arent in the jdm and the years 1999 jdm later aus.
id personally buy a jdm spec r over an australian one.
sorry.. i cant find the site..
but its a webpage of someone on this forum, with a fully JDM converted white S15..
i remember, it had a popup dash monitor, and headlight washers, rear wiper.. stuff like that..
different tubro
electric fold mirror
crimate control
A pillar boost gauge
badge
rear wipers
180 speedo
silightly different head light
surprise, u pay less insurance for Jap import S15 than aus. S15 due to the accident rate
and u can have a Jap S15 for high 20' instead of low-mid 30" aus. spec
To summarise:
JDM > AUS
climate control
xenon hid headlights
tv screen/sat-nav/md
rear windscreen wiper
factory boost gauge/a-pillar
180km instrument cluster
fog lights
ignition keylight illumination
heaps more, see
http://www.bengoodger.com/cars/silvia/jsit...s/options.shtml
*tv screen/sat-nav/md
are option but not standard
i read a few aus. magazine when the car release, mention about smaller tubro in aus. spec due to esmissionyep only jap spec
s15s have BB turbos,
ozzy delivered s15s are non BB, but roll bearing turbos..
i GUESS there is no way a factory Jap S15 is tune for 100 octane, so the jap spec should preformace 184kw in aus. fuel
Originally posted by HKSgtst
i'd get a Jap spec one. As they are cheaper, more powerful and rarer.
But nowadays S15s are everywhere. oh yeah, its hard to find a good condition jap spec S15.
you'll make the savings buying a jap spec model, but you'll end up paying it all back or even more to insurance...
oz delivered s15 are heaps easier and cheaper to insure
not really
someone found out that Jap spec is CHEAPER to insure due to the accident rate of Aus. spec is so high.
It is cheaper to insure a Aus spec S15, Im sure of it having been on the silvia forums for awhile.:uh-huh:
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
