So whos your cousin? Hahaha just jokes.
Its an investment really.
lol he's a soldier good luck breaking in an stealing it lol. I tried to put a photo up but cant upload bmps :(
oh an the house would have been a better one i would have thought lol
lol he's a soldier good luck breaking in an stealing it lol. I tried to put a photo up but cant upload bmps :P
My intentions didnt involve stealing it..... Haha
Can't you hit save as and put the format to JPEG?
dropped Impalas - so many levels of awesome.
Thats serious H-town texas style... swangin to the left and the right, ridin' on 20" daytons
kadina video was good to watch since i wasnt there
incidentally, the upcoming riverland auto expo in renmark will have a dyno there :)
-D
I'm thinking I might go a tip something like this rather then twin stainless pipes? Hmmmm.
Some RB30DET VL goodness :D.
Can't wait to see that launch at Jamboree this year :ninja:.
That on the 2step is going to sound insane.. should be good for mid 7's.
Fuuu.. making me reconsider heading over to jambo.
This is what happens when hektiks have too much money, 24ct gold plated quad rotor. :ninja:
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
