  • Replies 54
Posted Images
I'm looking forward to seeing this! Only 2 weeks now =P Still a bit intrigued that your NEO had the blanking bolt as opposed to a blank spot where a oil feed would go. I thought it was the non-NEO DE's that had the blanking bolt.
yeh it suprised me as well lol
mod list:
turbonetics stage 2 t3 turbo (450hp)
turbosmart ultragate 38mm
emu
gtt injectors
33 gtr pump
adj sard reg
adj exh cam gear
3" turboback
fmic
hoping for 200+
nice list, i have always liked their gt-k series with the black front housing.
but 1 thing im wondering... why choose a turbo that needs an external gate for now? if your aiming for 200-300rwkw, you could do that easily without an external gate...
how much psi u hoping to put in?
12psi atm.
i picked up this turbo for same price as a stock rb turbo and its a heap better turbo so i figure why not get it, has plenty of power left for future buildup if i choose to go down that path as well.
oh and ext gate sounds awesome!
12psi atm.
well if it was that cheap then why not!
but wot about the manifold tho? with manifold, turbo and gate id imagine you could get a internally gated aftermarket turbo for the same price? or was this setup alot cheaper?
im only para because of the popo in melb... might not be as bad for u....
and yes.. external gates sound pretty bloody nice.
The biggest issue is if you use the stock ECU and a piggy-back, counter-tuning the stock timing is a little time consuming.
If you keep the compression high, the best thing to do is get a larger than stock sized turbo if you want to run pressure over 9psi, flowing the exhaust gasses out as quick as possible is better to stave of detonation. I've seen T04E's on these engines spool like stock from the higher energy combustion that you get from high-comp.
The fitment is pretty easy, can be done at home over a weekend with no real dramas.
When you say spool like stock..? I've never had the joy of driving a factory turbo..
So you wouldn't recommend running more than 7PSI for a factory R33 GTSt Turbo? I'm still running 7 PSI of the actuator, eventually planning to get a EBC, possibly a Gizzmo as they seem to be very reliable and excellent value for money. So perhaps it's best to have a larger turbo before running more than 7 to keep some sort of reliability?
haha yeah I just mean come on boost earlier, some turbos get a good 1000rpm earlier boost than if they were on a 9:1 engine, nice :laugh:
You can run more than 7psi, just you may need to lose some timing in order to do it...and it may be one of those things were the gain of boost ends up not netting much extra in power. A turbo with a bigger rear housing will make more use of the extra gas flow and as a result you can run more boost as the heat is getting out of the combustion chambers quicker.
the 33 GTST stock turbos are reliable at 10-12PSI afais. mainly on RB20s as there isnt as much stress on them as they dont spool up as quick as on the 25s. its when you go to 14 that you start having reliability issues.
Dan, are you saying having a larger dump/front pipe reduces detonation? (makes sense really when i think about it)
From the way I understand it, you want to get the gas out of the engine quickly. Too small a turbo and it will become a restriction to flow. Just like say an old factory cat converter in a high powered car, except that after the manifold, the turbo is the first place hot air ends up after it leaves the engine.
I would imagine that the front/dump pipe should be a size that allows the air to flow and scavenge optimally. Too big and you reduce the efficiency of the exhaust system. Would I be right in my thinking by saying that changing to a larger front/dump pipe but not touching the turbo would be like fitting a larger catback system, but not changing a restrictive cat? If a front and dump is able to flow enough for the given amount of power (lets say 3" for the average N/A+t), but the turbo isn't able to pass through the exhaust gasses quickly, then the restriction isn't the front/dump and changing to a larger front/dump isn't going to make much of a difference.
The goal would be to get the exhaust gasses out of the engine and out of the turbo quickly, therefore making power and more of it, efficiently, and lowering the time that hot air stays in the engine and turbo, therefore reducing chances of detonation.
Please correct me if I'm wrong
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
