excuse my n00bness i only just got it last weekend! but.....here goes,
with my SeriesII RSFour S
when i'm in first, i can hit i think 5500ish RPM then it feels like it holds at 5500RPM,
and i have to change gear.... then second will go past 5500...
has that got something to do with the ECU limiting how far i can push it in first?
or something else u think?
:banana:
Tomas.
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/
oh i just read a post about 5500 Rpms and the boost dropping...
i'll have to keep an eye on my boost, my rpm and the road all at the same time so wish me luck haha
( or just get a friend to sit in and help )
:blink:
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4632158
i'm sure the 4WD models don't have traction control, only the RWD ones so it wouldn't be that.
when you say its holds at 5500 rpm does it feel like a rev limit of more of a flat spot? if it feels like a flat spot it could be a few things, could be the intake pipe sucking closed a bit, if you still have the stock exhaust or dump/front pipe you could be feeling the restriction. it also could be the slight flat spot experienced when the VVT switches off (around 5k rpm).
Edited by QWK32
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4632259
it did feel more like a flat spot than a limit maybe.. i'll try and figure exactly where and when its happening! :D
actually noticed a small exaust bandage after having a good look, would that be the source if its not sealed 100% ? :)
i think its a 3" exaust system from the looks of it
might have to get some help with this one i'm quite a n00b.
it came with an aftermarket intercooler on the front, with nice shiny pipes :)
aswell as an aftermarket pod filter and a BOV.
i'll keep investigating..
Edited by atomaly
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633250
LOL.
I still don't know how you got all that passed road worthy (let alone VicRoads).
Do you have the stock ECU or is there a piggyback installed?
Not sure why you need to hit 5.5k in 1st gear though!
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633515
LOL.
I like to hit redline in first, it's just fun :D
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633523
Why? Why not! lol. Besides, the old RB25 doesn't really open up till around 5k rpm.
yeah its a bit laggy down low, really opens up 4.5->6.5 , i was just a bit unsure as to why it wont get deep into the 'nice range' in 1st.
maybe give SSV a call about it??? for my case i'm saying it came with the car stock standard from the dealer :) i didnt do the RW or register it. :D
i'm not sure about if its a stock ECU i'll have a check tonight!
checked my intercooler thismorning.... its a "Blitz" from what it says on it.
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633694
4.5-6.5??
You may want to check if you a "stock" turbo hiding down there.
Don't think Nissan made a turbo with that much lag from factory.
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633711
4.5-6.5??
how do i know if its a stock turbo or not ? i've never had a turbo'd car b4 :D
its all rather exciting :D
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633806
Note that he can go past 5000 in other gears just not 1st!
what boost controller is it running? I know the AVC-R that I have you can limit boost by gear, so that could be it - but even if that WAS it , would make no sense as you can still rev past 5000 if you are still making normal boost.
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633883
might have to get someone to help me out in this area,
i'm a little bit limited in what i know (n00b :D )
i'm like a sponge at the moment. :D
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633912
No joke it blows.
Ive done the majority of bolt ons (coil packs, plugs, FMIC, 3" turbo back, EBC, SAFCII, SITC, Coil overs, camber arms, toe arms ect ect...) and its just starting to pull pretty well just if it had a real gear box :'(
https://www.sau.com.au/forums/topic/272870-rpm-and-ecu/#findComment-4633969
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
