No joke it blows.
Ive done the majority of bolt ons (coil packs, plugs, FMIC, 3" turbo back, EBC, SAFCII, SITC, Coil overs, camber arms, toe arms ect ect...) and its just starting to pull pretty well just if it had a real gear box :'(
:D the M35's dont come in manual at all yeah ??? unless ur a conversion king :D
i like the look of the C34's better anyway.
i was always like... *sigh* normally getting a manual = less $$. unless ur buying a stagea then its well into the other direction.
mine is a c34 mate :D
thinking of converting but mann its so pricey. prob will just get a shift kit.
yep i know man :D might be easier selling and buying a manual ? when i first looked u couldnt get a good manual for under 24k...
was just talking in general about M35's and that i dont think i'll ever own one.. hehe
C34's FTW
oh... that must mean u have leather interior ? *jealous*. i WAS thinking about modding my interior by finding a wrecked C34 with leather.. mmmm twin sunroof, manual, leather, black,. sexy.
4.5-6.5??
You may want to check if you a "stock" turbo hiding down there.
Don't think Nissan made a turbo with that much lag from factory.
it wouldn't be that the turbo is laggy it'll still come on full boost by 2500 rpm, with the RB25DET you don't start to feel the engine really pulling hard until around 4000 rpm.
Edited by QWK32
Only in RWD (6 speed manual)
OOOo so they do come in manual! :(
lol. To each their own Thomas.
Would like to compare your modded C34 with my very lightly modded M35 sometime!
sounds fun :D i'm actually keen to get a dyno to see exactly what mines pulling atm b4 i change anything (if i even need to) :D
Edited by atomaly
Yeah I've got Leather. Was one of the must haves when I was buying ;) How did you pick it?
i've actually been keeping an eye out for a year or so looking for the perfect one...(was always after black) and it fell into SSV. and i was REALLY tempted a couple of months ago but resisted until now and just went f**kit. i'm buying this cos no one else has bought it and i cant keep driving past it and wishing it was mine :D
i was also aware that manuals didnt come in leather. :(
so then i had to choose. and its easier to put leather interior in than change transmission i figured :P
the twin sunrooves just put the cherry on top :D
could be the slight flat spot experienced when the VVT switches off (around 5k rpm).
okay had a bit more of a play this weekend.
it will go past 5.5 just needs a bit of encouragement... :P i think i was just hesitant to push it hard :down:
(and after going past the first time..... second time felt like it was a tad smoother... wierd.... (a blockage of some sort???))
sortof stutters abit around the 5ish mark still..... would that be the VVT? :P
i was so glad when i saw it hit the red line in 1st :P
this dyno next week will give me a good idea of whats happening anyway!
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
