Gday guys,
Just wanted to get a feel off someone who's had the work done before;
I got quoted $1400 for supply and fitting of the following items;
F-Swaybar 24mm-h/duty Blade adjustable BNF24Z $229.09
R-Swaybar 22mm-X heavy duty BNR11X $229.09
Caster adj kit-radius rod bush KCA331 $125.73
Sub-frame align & lock kit KCA349 $124.91
That's about $700 worth of labour... seems pretty excessive to me, but i dont know how much work is actually involved...
So in summary, that's front+rear swaybars, pineapples, radius rod bushes and an alignment.
What do you think? Should I be looking for another quote and if so, where?
https://www.sau.com.au/forums/topic/272883-whiteline-suspension-work/
try and get 25 more off of the pineapples, and ~200 off of the labor IMO. Depends how much work fitting pineapples is. I estimated based on fitting both end camber kits being the same as fitting pineapples.
I would consider doing camber kits at the same time, just so it is all the same age, and won't need another alignment.
If they're supplying it, as well as fitting it, I’m assuming they've done that type of work before? It does seem a bit excessive though, even if they charge $100 p/h, but they may just be over quoting. It might pay just to ring around and get a quote elsewhere to compare.
Pedders wanted to charge me $20 for each bushing they would press out. I said yeah no worries (insert sarcasm) and ended up doing it myself. Yes it took longyer, yes I have higher blood pressure as a result. But I saved near $500 and love my car even more!
As above, do what you can, search the forums and ask for advice from people who know.
swaybar fitting was probably too easy to get its own thread, so I will try in 3 easy steps:
jack up you car and put it on stands on LEVEL ground
undo the links at either end of the swaybar where they connect to the lower control arm,
undo the 4 bolts that hold the bracket for the sway bar, and remove the sway bar.
then, as the workshop manual says...."installation is the reverse of removal"
this is one easy job. personally I wouldn't try bushes myself without the right tools and knowledge, there are some tricks with pressing out and back in, to me its one of the jobs that it is easier to pay fo.
Thanks Duncan. I did the sway bars today, easy as pie, and really makes a big difference to the feel of the car around corners. Hardest part was I needed to remove the radius rods to get at the d-bracket bolt. All up, took about 2 hours.
As for the radius rod bushes, when the mechanics open, i'll get someone to pop out the old bushes, and pop in the new. Installation of the rod itself will be easy.
Then just the pineapples to go. Would have done it today, but ran out of time and needed to get to work :( bummer
Hopefully should have it all ready for Oran Park :)
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
