why dont you just do the maths on paper to workout the best turbo and go from there?
because this is australia my friend.. and there arent many people like u or myself who would like to do things properly.. hence y 90% of shit is half assed
"easier" to bolt different turbos rather than read a comp map against engine flow characteristics
https://www.sau.com.au/forums/topic/273046-oh-dear/page/2/#findComment-4635442
well we have done that to a point where we like the t04e, and we wanted to trial it.
if the trials go the same way as the maths then we have done something right :)
and we will get a genuine garrett
but at this stage the china copy has been quite good, just this issue about spinning has been the only thing
and its been really good to learn about the differances between different brands as were only reasonably new to the sport.
the forum has allready helped us to narrow down the selection, were just in the testing phase now ;)
https://www.sau.com.au/forums/topic/273046-oh-dear/page/2/#findComment-4635647
yeah fair enough
I am a little open minded when it comes to these china turbo's. i saw one r33 with 360rwkw and has done for a year or more. not sure how much more it lasted though.
https://www.sau.com.au/forums/topic/273046-oh-dear/page/2/#findComment-4635688
well thats the thing, even reading around on here and elsewhere, there are almost equal positive to negative stories, and many of the negative stories of the china turbos appear to be beased on hearsay, the actual people running th egear seem to be reasonably happy with it.
yes its from china.
so?
it seems that bar a few teething issues some of these turbos are ok, and thats what i really want to find out
https://www.sau.com.au/forums/topic/273046-oh-dear/page/2/#findComment-4635765
if the trials go the same way as the maths then we have done something right :D
Genuine Garrett what?
A TO4E is a 30yr old design... you could buy something much newer and gain some really good performance
https://www.sau.com.au/forums/topic/273046-oh-dear/page/2/#findComment-4635908
yeah fair enough
Yeah I'm a bit on the fence... the fella that i sold my set-up to said it lasted about 10 mins... but he looked like he was pretty rough with his gear and installs... judging by his RX7...
But my brother put on on his VP wagon...
Ran 17.xx before can't remember MPH,
But now he's running 13.3 @ 107MPH... doing a good job till the oil seal went in it...
https://www.sau.com.au/forums/topic/273046-oh-dear/page/2/#findComment-4636694
yeah i was hearing similar stories aswell, but so far it has not had a problem, and i like the T04e atm as its more responsive then the t 70, but idealy i would hang a gt35r on the side, but we will see.
i solved it today by the way, i slowly manually spun the wheel while dripping oil in the feed and letting it come out the return, did this for a few minutes and let it sit, connected it all up again, toped up the oil and away it went, no dramas
https://www.sau.com.au/forums/topic/273046-oh-dear/page/2/#findComment-4636724
lol sorry i didnt put that right, turns out when i removed the inlet one of the times a bit of swarf fell in the hole, but not all the way into the chamber, so the oil coimg in was being slowed down heaps by the swarf sticking back up into the feed.
so by taking it all off and spinning it around manually showed that there was no actual problem with the turbo, but the oil feed, so i looked inside the hose and found the swarf sticking up inside, removed it, re attached it. and hey presto :banana:
https://www.sau.com.au/forums/topic/273046-oh-dear/page/2/#findComment-4636743
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
