Hey Carlos,
Sorry for the delayed response.
I will call you sometime after Saturday 20th, as i have drift school and have purchased a new car.
Will have more funds after the 20th, but if they sell in the meantime, than let it be :P
Regards
  • Replies 114
Posted Images
Has anyone received their goods from Carlos yet?
He wouldn’t send via Australia Post COD so I opted out.
http://www.auspost.com.au/BCP/0,1467,CH2147~MO19,00.html
Also didn't want to use internet banking...
Guest carlos187
He wouldn't send via Australia Post COD so I opted out.
i have no issue with you using internet banking mate i just told u ive had issues with that it thats all ok and ill answer that question 4 u 3 item are on the way 2 the buyers thank you dnt bother calling me bak 4 the fuel pump dnt want 2 sell it to a gronk like u anyway mate dnt like timewasters thanks have a good day
How much for both front gaurds, and whole rear subframe? Including Diff, shafts, hubs etc delivered to adelaide 5037?
Are you also selling the rb26 head and plenum (whole left hand side of the motor) and gearbox?
Cheers
Edited by Luke_ENR34
Guest carlos187
Cheers
please call me on 0424253000 or send ur number through i call u and we will organise a reasonable price that suits both of us lunky u i still have front guards and whole rear sub frame availble.
hey carlos,
sent you a sms but just incase you didnt get that ill post here.
was suppose to hear from you today about shipment as i paid in full over a week ago. starting to get a bit worried so please get back to me asap.
0421691338 is my number.
dont let me down buddy
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
