  • Replies 112
Damn bike handle sticking out the side.. just noticed that :)
Sidd - thanks man.. yeah I absolutely love the colour.. althoug the cops up at Erina don't hahha
Cops pulled up next to me looked at my wheels and said "you gotta be f**king kidding me right haha" hahaha
i think my next body will be a 5dm2!! cant wait
I used my friends one for a while and i loved it!!
Yeah, I love my 24-70 2.8L even more now~! Kinda makes my 40D feel like a toy now, Lol. I was unkeen at first cause of the video recording feature on it. But its a fkn cool feature I must say.
Edited by Lepperfish
just upgraded to a 5dm2 but just got the stock 24-105 F4 plus a 50mm prime.
few shots of the old mans 32 Deuce coupe when i was back home in VIC for a week
loving being able to handhold indoors with no flash and still have easially usable 3200iso shots!
I couldn't agree more..
And my friend had the 24-70 as well.. I loved it!!
Wish i had the money for one..
My next combo will deff be 5dm2 with 24-70 :P
Yeah man, its sweet. Pity how expensive they are at the moment. I picked up all my glass hella cheap.
I got the 24-70 2.8L - 70-200 2.8L IS - 400 5.6L - 135 2.0L - 100 2.8 Macro and a useless EF-S 10-22 that is for sale. Although I'm keeping my 40D body I don't want any EF-S lenses. Think i'll get the 14mm 2.8L next.
A31cefiro - another one with a mdm2!! damn you all hahah
Beautiful car i must say!! nice :banana:
slim - heheh cute dog.. Does it have blue eyes??
Lepperfish - i hate you even more when you listed your gear!! hahahh nah nah all good.. Looks like you got a crazy combo of lens!!
yea dont sell the 40d. It will be a good 2nd body!!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
