This car has been fully re built 10000 klms ago. it has forged pistons shot peened rods, ported and polished head, The block is o ringed, it has a custom made inter cooler on it, it has a reconed machenical lsd awsome traction. it has a turbo smart blow off valve vee port 2 an ms fuzzy boost controller some kind of turbo timer, for an extra 1200 i will put a titanium exhaust on for you it still has standard turbo but still 240 hp at the wheels at 1 bar of boost about 14.5 pounds of boost i think. All this for 23000aud ono. I must sell by the end of the week so call me or put post up, but i will only send photos to those who ring me on 0422271237 try after 7pm est it also has fully reconditioned air conditioner has aout 6 months rego
look if you want photos emailed just leave your email in the post replys but i do prefer to answer questions by telephone. the car also has brass button clutch and grind fly wheel this car is built this engine is built for big turbos with a compresion ratio of 8.5 to 1remember call Imight take 22 000
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
